termios
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Apr 28 17:46:28 UTC 2003
Thomas Doerfler wrote:
> Hello,
> I think you refer to the loop starting with
> while (tty->rawInBuf.Head != tty->rawInBuf.Tail) {
> in function "fillBufferQueue" in termios.c.
> IMHO a solution would be to limit the loop to the cases, when
> the variable "wait" ist still TRUE, so a replacement for the
> upper line would be
> while (wait && (tty->rawInBuf.Head != tty->rawInBuf.Tail)) {
I think either will work but changing the semantics of the checks being
made
separately scares me a bit without doing more analysis.
I think Wolfram's solution is correct and less likely to perturb things.
Can one of you file a PR once the patch is tested?
FWIW my first job out of college was porting the System V TTY driver
to an embedded environment. It was an intelligent serial controller
and the card pretty closely mapped section 2 system calls. The code
was incredibly complicated and the RTEMS termios driver is a piece of
cake to read compared to that. :)
--joel
> wkr,
> Thomas Doerfler.
> > Hello,
> > we are struggling with the termios system in the moment and we need the
> > help of the community.
> > either there is a missunderstanding of cannonical processing by us or a
> > real bug in the termio system.
> > the function fillBufferQuue() is responsible to transfer from raw input
> > buffer into cooked buffer and all the control character processing is
> > handled by iproc(). when iproc() signals a completed line by returning a
> > one, fillBufferQueue does not return to the caller with this line in the
> > cooked buffer, but remains in its loop and appends all further
> > characters (after cannonical processing) to the cooked buffer. IMHO
> > fillBufferQueue should return immediately after an NL, EOF, EOL or EOL2
> > was added to cooked buffer.
> > this behaviour could be accomplished by adding a break instruction after
> > the wait = 0; instruction after calling siproc() in cannonical processing.
> > Schöne Grüße aus Reutlingen
> > Wolfram Wadepohl
> > Entwicklung
> > INDUMAT GmbH & Co. KG
> > Transport- und Lagersysteme
> > Dieselstraße 6
> > D-72770 Reutlingen - Betzingen
> > Tel. +49 (0)71 21/5 14-2 89
> > Fax +49 (0)71 21/5 14-2 99
> > eMail W.Wadepohl at indumat.de
> > WWW http://www.indumat.de
> > Bitte senden Sie mir keine Word- oder PowerPoint- (tm Microsoft) Anhänge.
> > Senden Sie mir einfachen Text, HTML oder PDF.
> > Siehe http://www.fsf.org/philosophy/no-word-attachments.de.html
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at: http://www.imd-
> systems.de/pgp_keys.htm
joel at OARcorp.com On-Line Applications Research
