termios
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Tue Apr 29 10:54:21 UTC 2003
Hello,
ok, I agree, my proposed solution would
definitivly change/break the behaviour of non-
canonical mode, so Wolframs solution seems the
better/proper way to do it.
wkr,
Thomas.
> Joel Sherrill schrieb:
> >Thomas Doerfler wrote:
> >>Hello,
> >>I think you refer to the loop starting with
> >> while (tty->rawInBuf.Head != tty->rawInBuf.Tail) {
> >>in function "fillBufferQueue" in termios.c.
> >>IMHO a solution would be to limit the loop to the cases, when
> >>the variable "wait" ist still TRUE, so a replacement for the
> >>upper line would be
> >> while (wait && (tty->rawInBuf.Head != tty->rawInBuf.Tail)) {
> >I think either will work but changing the semantics of the checks being
> >made
> >separately scares me a bit without doing more analysis.
> There is adiffernce between my solution and Thomas'. with the inserted
> break only in cannonical processing input is terminated with either a
> NL, EOF, EOL or EOL2. in non cannonical processing as much as available
> characters are returned to the application. IMO this the right way,
> because in non-cannonical mode there is only a lower limit of chars
> VMIN, termios should return as much characters as available.
> >I think Wolfram's solution is correct and less likely to perturb things.
> >Can one of you file a PR once the patch is tested?
> >FWIW my first job out of college was porting the System V TTY driver
> >to an embedded environment. It was an intelligent serial controller
> >and the card pretty closely mapped section 2 system calls. The code
> >was incredibly complicated and the RTEMS termios driver is a piece of
> >cake to read compared to that. :)
> >--joel
> >>wkr,
> >> Thomas Doerfler.
> >>>Hello,
> >>>we are struggling with the termios system in the moment and we need the
> >>>help of the community.
> >>>either there is a missunderstanding of cannonical processing by us or a
> >>>real bug in the termio system.
> >>>the function fillBufferQuue() is responsible to transfer from raw input
> >>>buffer into cooked buffer and all the control character processing is
> >>>handled by iproc(). when iproc() signals a completed line by returning a
> >>>one, fillBufferQueue does not return to the caller with this line in the
> >>>cooked buffer, but remains in its loop and appends all further
> >>>characters (after cannonical processing) to the cooked buffer. IMHO
> >>>fillBufferQueue should return immediately after an NL, EOF, EOL or EOL2
> >>>was added to cooked buffer.
> >>>this behaviour could be accomplished by adding a break instruction after
> >>>the wait = 0; instruction after calling siproc() in cannonical processing.
> >>>Schöne Grüße aus Reutlingen
> >>>Wolfram Wadepohl
> >>>Entwicklung
> >>>INDUMAT GmbH & Co. KG
> >>>Transport- und Lagersysteme
> >>>Dieselstraße 6
> >>>D-72770 Reutlingen - Betzingen
> >>>Tel. +49 (0)71 21/5 14-2 89
> >>>Fax +49 (0)71 21/5 14-2 99
> >>>eMail W.Wadepohl at indumat.de
> >>>WWW http://www.indumat.de
> >>>Bitte senden Sie mir keine Word- oder PowerPoint- (tm Microsoft) Anhänge.
> >>>Senden Sie mir einfachen Text, HTML oder PDF.
> >>>Siehe http://www.fsf.org/philosophy/no-word-attachments.de.html
> >>IMD Ingenieurbuero fuer Microcomputertechnik
> >>Thomas Doerfler Herbststrasse 8
> >>D-82178 Puchheim Germany
> >>email: Thomas.Doerfler at imd-systems.de
> >>PGP public key available at: http://www.imd-
> >>systems.de/pgp_keys.htm
> Wolfram Wadepohl
> Entwicklung
> Dieselstraße 6
