Configure flags no longer working.
Steven Johnson sjohnson at neurizon.net
Wed Apr 30 12:51:03 UTC 2003
To Put a finer point on it:
This is what I did, and it appears to have solved the problem (thanks Ralf):
export CFLAGS_FOR_TARGET="put flags here"
export CXXFLAGS_FOR_TARGET=$CFLAGS_FOR_TARGET
./configure --usual-options-except-enable-bare-cpu-cflags
make all install
NOTE:
"put flags here" means this is where you put the compiler flags you want
to build RTEMS with.
--usual-options-except-enable-bare-cpu-cflags is not an option of
configure, it is a shorthand representation for all the options a person
may normally use to pass to configure, except for
--enable-bare-cpu-cflags which doesn;t do anything anyway for V4.6.0 pre 3.
Steven
Ralf Corsepius wrote:
> Am Mit, 2003-04-30 um 07.51 schrieb Steven Johnson:
>>I am having problems configuring Pre2.
>>--enable-bare-cpu-cflags does not work anymore.
>>There is no explicable reason why.  This fatally kills my build, as I
>>need to force -msoft-float, but it doesn't happen.  So my program gets
>>filled with floating point, and I don't have a floating point unit.
>>Does anyone know what happened to --enable-bare-cpu-cflags  ??
> It currently is broken. I answered this question a couple of weeks ago.
> Please check this list's archive.
>>I can't see any changelog entry for it.
>>How do I fix this?
> Use *_FLAGS_FOR_TARGET instead.
> Ralf
