RTEMS make errors for i386ex
Aditya avpenu at essex.ac.uk
Fri Aug 1 12:27:59 UTC 2003
Hi,
After successfully configuring RTEMS ...
I type the command ( for i386ex BSP)...as below and I get the errors
after that...
$ make all install
/opt/rtems/i386-rtems/include/sys/types.h : 246 : syntax error before
"clockid_t"                         ____ / ----------------//ERROR
/opt/rtems/i386-rtems/include/sys/types.h : 251 : syntax error before
"timer_t"                                    \ ---------------//ERROR
make[7] : *** [o-optimize/cpu.o] Error 1
How can I remove these errors?
What should be the messages if it is a successful make?
Regards
Aditya <http://privatewww.essex.ac.uk/~avpenu>
URL: <http://lists.rtems.org/pipermail/users/attachments/20030801/eaee4bdc/attachment.html>
