Error during gmake after applying patch with PR 450 to rtems-ss-20030703
Aditya avpenu at essex.ac.uk
Mon Aug 18 17:37:11 UTC 2003
Dear RTEMS Users,
After applying the patch PR 450 to linkcmds...and successful
configuration...
RTEMS gives following error during gmake..(some of the samples like
hello,base_sp,loopback,minimum,paranoia,ticker,unlimited were made into
.exe)
[aditya at localhost build-rtems]$gmake RTEMS_BSP=i386ex
gmake[5]: Entering directory
`/home/aditya/tools/build-rtems/i386-rtems/c/i386ex/tests/samples/pppd'
mkdir o-optimize
i386-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../i386ex/lib/
-specs bsp_specs -qrtems  -DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
-DPACKAGE_VERSION=\"ss-20030703\"
-DPACKAGE_STRING=\"rtems-c-src-tests-samples\ ss-20030703\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at OARcorp.com\"    -isystem
../../../../../i386ex/lib/include     -msoft-float  -O4 -g -Wall  -ansi
-fasm  -o o-optimize/init.o -c
../../../../../../../rtems-ss-20030703/c/src/tests/samples/pppd/init.c
i386-rtems-gcc - -pipe -B../../../../../lib/
-B../../../../../i386ex/lib/ -specs bsp_specs -qrtems
-fasm  -o o-optimize/pppdapp.o -c
../../../../../../../rtems-ss-20030703/c/src/tests/samples/pppd/pppdapp.
-specs bsp_specs -qrtems -msoft-float  -O4 -g -Wall  -ansi -fasm
-o o-optimize/pppd.coff o-optimize/init.o o-optimize/pppdapp.o
../../../../../i386ex/lib/no-dpmem.rel
../../../../../i386ex/lib/no-msg.rel ../../../../../i386ex/lib/no-mp.rel
../../../../../i386ex/lib/no-part.rel
../../../../../i386ex/lib/no-signal.rel
../../../../../i386ex/lib/no-timer.rel
../../../../../i386ex/lib/no-rtmon.rel
o-optimize/init.o: In function `Init':
/home/aditya/tools/build-rtems/i386-rtems/c/i386ex/tests/samples/pppd/..
les/pppd/init.c:23: undefined reference to `tty1_initialize'
les/pppd/init.c:23: undefined reference to `tty1_open'
les/pppd/init.c:23: undefined reference to `tty_close'
les/pppd/init.c:23: undefined reference to `tty_read'
les/pppd/init.c:23: undefined reference to `tty_write'
les/pppd/init.c:23: undefined reference to `tty1_control'
les/pppd/init.c:23: undefined reference to `tty2_initialize'
les/pppd/init.c:23: undefined reference to `tty2_open'
les/pppd/init.c:23: undefined reference to `tty2_control'
collect2: ld returned 1 exit status
gmake[5]: ***  [o-optimize/pppd.exe] Error 1
gmake[5]: Leaving directory
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving  directory
`/home/aditya/tools/build-rtems/i386-rtems/c/i386ex/tests/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]:  Leaving directory
`/home/aditya/tools/build-rtems/i386-rtems/c/i386ex/tests'
gmake[2]: *** [all-recursive] Error 1
gmake[2]:  Leaving directory
`/home/aditya/tools/build-rtems/i386-rtems/c/i386ex'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving  directory
`/home/aditya/tools/build-rtems/i386-rtems/c'
gmake: *** [all-recursive] Error 1
Regards
Aditya
