Error even with dmv177
Ralf Corsepius corsepiu at faw.uni-ulm.de
Wed Aug 20 13:58:19 UTC 2003
On Wed, 2003-08-20 at 15:28, Leon Pollak wrote:
> OK, I returned the dmv177 BSP and the result is the same error as with MY_BSP
> instead of dmv177 in config.ac in ../powerpc (after rerunning bootstrap from
> ../powerpc directory):
> Making preinstall in powerpc
> gmake[6]: Entering directory
> `/opt/rtems/rtems-bin/build/powerpc-rtems/c/MY_BSP/lib/libbsp/powerpc'
> gmake[6]: *** No rule to make target `preinstall'.  Stop.
> Sorry, for stupidity - what did I do incorrect?
I don't know ;) I'd recommend you to compare your BSP's Makefile.ams and
configure.ac against their counterparts in the dmv177.
Seems as if your lib/libbsp/powerpc/MY_BSP/Makefile.am doesn't include
automake/local.am
I.e. probably your BSP's toplevel Makefile.am lacks this:
include $(top_srcdir)/../../../../../../automake/subdirs.am
include $(top_srcdir)/../../../../../../automake/local.am
BTW: Also make sure to have
c/src/lib/libbsp/powerpc/MY_BSP/bsp_specs
Otherwise bootstrap won't add your BSP to libbsp/powerpc/acinclude.m4
Ralf
