Intel X-Scale
Brett Swimley brett.swimley at aedinc.net
Wed Aug 20 20:28:35 UTC 2003
Michael - Thanks for the response.  I'll check out the website and
educate myself a bit more.
I think we're looking specifically at the IXP420 Network Processor,
which (correct me if I'm wrong) would be similar to the PXA255 with
different peripherals.
Regards,
Brett
Michael Kelly wrote:
>Brett,
>Much solid work has already been done for ARM by OAR (Joel?) and
>by Jay Monkman.  The architecture work should be nearly 100%
>the same as the MMU and cache models are identical.  Obviously
>there will be peripheral differences, but you can look at our boot
>monitor (umon) source code for init and simple polled drivers for the
>PXA255, serial, LCD and SDRAM.  The link to the umon source is
>on our web site (www.cogcomp.com).  We are planning an RTEMS port
>to our CSB352 PXA255 board, but it wouldn't ready be until Oct. or Nov.
>Regards,
>Michael
>At 03:54 PM 8/20/2003, Brett Swimley wrote:
>>Hi all,
>>We're looking at several flavors of Intel X scale processors for possible use in upcoming projects and I'm just starting to familiarize myself with them. Do these processors have support and/or BSP's developed for RTEMS?
>>I haven't done much research yet, but I get the indication that these are ARM processors....
>>Regards,
>>Brett Swimley
>Michael J. Kelly
>VP Engineering/Marketing
>Cogent Computer Systems, Inc.
>1130 Ten Rod Road
>Suite A-201
>North Kingstown, RI 02852
>tel:401-295-6505 fax:401-295-6507
>www.cogcomp.com
>alternate email: mkelly6505 at hotmail.com
