Question about _init, _fini
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Thu Aug 21 18:52:04 UTC 2003
mikeci at acm.org writes:
 > Hi!
 > I have a problem with _init, _fini. When using gcc 3.2.1 everything works
 > ok, but with gcc-3.2.2 linker can't find those two symbols. Do I need to
 > modify my linker script?
 > Regards
 > Ivica
Quite likely yes.  Look for the .init and .fini sections of a linker
script for another bsp using a processor similar to yours- if you're
using a MIPS, have a look at the MongooseV's link script, you'll find
it down in the bsp directory.  WHile you're at it, you might want to
check the other sections too, linker scripts evolve and sometimes
leave bsp's behind.
Gregm
