powerpc-rtems-gcc compiling problem
Fri Aug 22 12:51:25 UTC 2003
Dhiraj wrote:
> Hello,
>  I am using cygwin to compile my stuff on windows. I was using an old 1998
> cygwin. Today I shifted to the latest cygwin and my compilation didn't work.
> Then I tried to compile a Hello world file. That too didn't work(same
> error). What could be the problem.
> This is the error :-
>>powerpc-rtems-gcc -c hello.c
> Assembler messages:
>  for reading.open
> : No such file or directory
> Seems like there is some misunderstanding between powerpc-rtems-gcc and the
> powerpc rtems assembler.Normal gcc is working fine and compiles the hello
> world without any problems.
If you updated cygwin, then you updated the native gcc to match the
cygwin version.  What powerpc-rtems gcc version is this?
Also I vaguely recall that something like this can occur when
a filesystem is not mounted in binary mode.
A big help in debugging problems like this is to add a -v to the
powerpc-rtems-gcc command line and watching what it invokes.
> regards
> Dhiraj
