serial connections to embedded targets
Bill Gatliff bgat at billgatliff.com
Sun Aug 24 01:19:05 UTC 2003
Chris:
I always use minicom.  Never tried to do it with xterm, in fact.
b.g.
Chris Caudle wrote:
>This is a little sideways to direct RTEMS topics, but does anyone on the
>list know how to connect an xterm (or similar KDE or Gnome terminal
>program) directly to a serial port?
>My embedded targets typically use a serial port for string output, which I
>can view using Hyperterm on Windows, or can view by using cat to output
>the contents of /dev/ttyS0 in Linux.  On Windows, Hyperterm is
>bidirectional, so I can send commands back to the embedded target, and I
>would like to be able to do the same thing from an xterm.  It seems it
>should be simple, but I can't figure out how to get xterm connected to
>/dev/ttyS0 instead of to a shell process.
>thanks,
>Chris Caudle
Bill Gatliff
Get real embedded GNU training from a real embedded GNU developer.
