question about test appliction sp02
Mon Aug 25 22:03:59 UTC 2003
Harris, Andrew wrote:
> Hi -
> 	I am running RTEMS on an MVME2604 with the MVME712 IO board.  I am
> using the unmodified MVME2307 BSP and things seem to be working.  I am able
> to get RTEMS to boot and execute the hello and ticker examples, as well as
> tests SP01, SP03, SP04 and SP05.  However, it seems test SP02 is failing.
> The error says TOO_MANY, but I can't seem to find whether it's too many
> tasks or too many global objects (it seems that error code is repeated for
> both of these conditions in the rtems_task_create case).  I looked in
> system.h for this test and it had CONFIGURE_MAXIMUM_TASKS set to 4, which
> should be enough for this test case...
I see no recent patches for this test.  It is certainly not too many
global objects as that would only occur in a multiprocessing
configuration.
> 	Does anyone think it could be something that I've not done in the
> BSP related code that is causing some strange error?  (I tried running the
> cdtest.exe file and it crashed when trying to boot, after loading with an
> INVALID INSTRUCTION error.  I'm wondering if this is all related to the
> BSP.)
Is the BSP creating any other tasks?  The tests only configure the
minimum resources they require.
It is possible that it is a driver somewhere that is
allocating a task and it is not accounted for.
> 	See the attached output:
> PPC1-Bug>nbo
> Network Booting from: DEC21140, Controller 0, Device 0
> Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
> Loading: tests/sp02.exe
> Client IP Address      = 128.244.239.38
> Server IP Address      = 128.244.239.39
> Gateway IP Address     = 128.244.239.1
> Subnet IP Address Mask = 255.255.248.0
> Boot File Name         = tests/sp02.exe
> Argument File Name     =
> Network Boot File load in progress... To abort hit <BREAK>
> Bytes Received =&155308, Bytes Loaded =&155308
> Bytes/Second   =&77654, Elapsed Time =2 Second(s)
> Residual-Data Located at: $01F78000
> Model: 000000000000000000000000000(e2)
> Serial: MOT040D86B
> Processor/Bus frequencies (Hz): 333374272/66673768
> Time Base Divisor: 4000
> Memory Size: 2000000
> Original MSR: 3040
> Original HID0: 82
> Original R31: 0
> PCI: Probing PCI hardware
> RTEMS 4.x/PPC load:
> Uncompressing the kernel...
> Kernel at 0x00000000, size=0x38d50
> Initrd at 0x00000000, size=0x0
> Residual data at 0x00039000
> Command line at 0x00040000
> done
> Now booting...
> Welcome to rtems-ss-20030417(PowerPC/PowerPC 604/mvme2307) on MVME 2600 with
> MVME712M
> OpenPIC found at C1000000.
> OpenPIC Version ? (2 CPUs and 17 IRQ sources) at 0xC1000000
> OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 2
> OpenPIC timer frequency is 8333592 Hz
> Please add code for PCI/ISA bridge init to
> libbsp/powerpc/shared/irq/irq_init.c
> If your card works correctly please add a test and set known_cpi_isa_bridge
> to true
> currentBoard = i
> Universe II PCI-VME bridge detected at 0xC1041000, IRQ 11
> Universe Master Ports:
> Port  VME-Addr   Size       PCI-Adrs   Mode:
> 0:    0xFFFFE000 0x00000000 0xFFFFF000 A??, Pgm, Sup
> 1:    0xFFFE0000 0x00000000 0xFFFF0000 A??, Pgm, Sup
> 2:    0xFFFE0000 0x00000000 0xFFFF0000 A??, Pgm, Sup
> 3:    0xFFFE0000 0x00000000 0xFFFF0000 A??, Pgm, Sup
> 4:    0xFFFFE000 0x00000000 0xFFFFF000 A??, Pgm, Sup
> 5:    0xFFFE0000 0x00000000 0xFFFF0000 A??, Pgm, Sup
> 6:    0xFFFE0000 0x00000000 0xFFFF0000 A??, Pgm, Sup
> 7:    0xFFFE0000 0x00000000 0xFFFF0000 A??, Pgm, Sup
> Universe Slave Ports:
> 0:    0xFFFFF000 0x00000000 0xFFFFE000 A??, Pgm, Dat, Sup, Usr
> 1:    0xFFFF0000 0x00000000 0xFFFE0000 A??, Pgm, Dat, Sup, Usr
> 2:    0xFFFF0000 0x00000000 0xFFFE0000 A??, Pgm, Dat, Sup, Usr
> 3:    0xFFFF0000 0x00000000 0xFFFE0000 A??, Pgm, Dat, Sup, Usr
> 4:    0xFFFFF000 0x00000000 0xFFFFE000 A??, Pgm, Dat, Sup, Usr
> 5:    0xFFFF0000 0x00000000 0xFFFE0000 A??, Pgm, Dat, Sup, Usr
> 6:    0xFFFF0000 0x00000000 0xFFFE0000 A??, Pgm, Dat, Sup, Usr
> 7:    0xFFFF0000 0x00000000 0xFFFE0000 A??, Pgm, Dat, Sup, Usr
> Overriding main IRQ line PCI info with 5
> Registering /dev/console as minor 0 (==/dev/ttyS0)
> *** TEST 2 ***
> INIT - rtems_task_wake_after - yielding processor
> PREEMPT - rtems_task_delete - deleting self
> rtems_task_create of TA3 FAILED -- expected (successful completion) got (too
> many)
> Once again thanks for any help,
> -andrew
