c++, new() error
Tue Aug 26 23:01:19 UTC 2003
Steve Strobel wrote:
> The README.configure file says the following:
> By default, the RTEMS support of C++ is disabled.  It can be enabled
> with the --enable-cxx option. If the rtems++ C++ library is installed
> it will also be build.
That's only the C++ class binding to the Classic API and associated
test.
--joel
> Steve
> At 09:21 PM 8/26/2003 +0200, you wrote:
>>Hy all,
>>I'm trying to see if is possible to use c++ on my board (which I have personally
>>wrtitten for an arm starting by an existing one.)
>>Now I'm able to compile an application which define static object, the only
>>problem is that I can't use new(),  because when I try compile the compiler give
>>to me that error:
>>/scratch/francesco/initialc++/init.cpp:44: undefined reference to `operator
>>new(unsigned long)'
>>delete(void*)'
>>delete(void*)'
>>/scratch/francesco/initialc++/init.cpp:51: undefined reference to
>>`__gxx_personality_sj0'
>>Someone know if is possible to have a board which use it? If yes what I need to
>>had in order to have it working?
>>Really thanks to all  Francesco.
> Steve Strobel                           WWW: http://www.link-comm.com
> Link Communications, Inc.               Phone: (406) 245-5002 ext 102
> MailTo:steve at link-comm.com              Fax: (406) 245-4889
