problem building from CVS on FreeBSD
chuck_tuffli at agilent.com
Sun Aug 31 13:51:22 UTC 2003
I'm trying to build RTEMS from the CVS head and am running into some
pretty basic problems. The host system is an x86 running FreeBSD 4.7
with autoconf 2.57 and automake 1.7 from ports.
After running configure and 'gmake all', I get the output below. Any
ideas why I get the messages about "Nothing to be done"? Thanks!
---chuck
[161] AUTOCONF="autoconf257" AUTOHEADER="autoheader257"
AUTOM4TE="autom4te257" AUTOMAKE="automake17" ACLOCAL="aclocal17"
../rtems/configure --target=i386-rtems --enable-docs
--enable-rtemsbsp=pc386
checking for gmake... gmake
checking for RTEMS Version... ss-20030703
checking build system type... i386-unknown-freebsd4.7
checking host system type... i386-unknown-freebsd4.7
checking target system type... i386-pc-rtems
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking whether gmake sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of
Makefiles... no
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /usr/local/bin/bash
'../../../rtems/tools/build/configure' '--prefix=/opt/rtems-4.7'
'--host=i386-unknown-freebsd4.7' '--build=i386-unknown-freebsd4.7'
'--enable-docs' '--enable-rtemsbsp=pc386' '--target=i386-rtems'
'--cache-file=/dev/null' '--srcdir=../../../rtems/tools/build'
Makefiles... no
checking for i386-unknown-freebsd4.7-gcc... no
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by gmake... GNU
checking dependency style of gcc... gcc
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... no
checking for unistd.h... yes
checking getopt.h usability... no
checking getopt.h presence... no
checking for getopt.h... no
checking for strerror... yes
checking for strtol... yes
checking for bash... /usr/local/bin/bash
config.status: creating Makefile
config.status: creating install-if-change
config.status: creating config.h
config.status: executing depfiles commands
configure: configuring in ./tools/cpu
'../../../rtems/tools/cpu/configure' '--prefix=/opt/rtems-4.7'
'--cache-file=/dev/null' '--srcdir=../../../rtems/tools/cpu'
checking rtems target cpu... i386
Makefiles... no
configure: configuring in generic
'../../../../rtems/tools/cpu/generic/configure'
--prefix=/opt/rtems-4.7 '--prefix=/opt/rtems-4.7'
'build_alias=i386-unknown-freebsd4.7'
'host_alias=i386-unknown-freebsd4.7' 'target_alias=i386-rtems'
--cache-file=/dev/null --srcdir=../../../../rtems/tools/cpu/generic
Makefiles... no
config.status: creating size_rtems
configure: configuring in ./doc
configure: running /usr/local/bin/bash '../../rtems/doc/configure'
'--prefix=/opt/rtems-4.7' '--host=i386-unknown-freebsd4.7'
'--build=i386-unknown-freebsd4.7' '--enable-docs'
'--cache-file=/dev/null' '--srcdir=../../rtems/doc'
Makefiles... no
checking whether ln -s works... yes
checking for perl... perl
checking for gs... no
checking for texi2dvi... no
checking for epstopdf... no
checking for texi2pdf... no
config.status: creating rtems_support.html
config.status: creating index.html
config.status: creating FAQ/Makefile
config.status: creating develenv/Makefile
config.status: creating user/Makefile
config.status: creating bsp_howto/Makefile
config.status: creating started/Makefile
config.status: creating porting/Makefile
config.status: creating networking/Makefile
config.status: creating posix_users/Makefile
config.status: creating posix1003.1/Makefile
config.status: creating filesystem/Makefile
config.status: creating itron3.0/Makefile
config.status: creating ada_user/Makefile
config.status: creating started_ada/Makefile
config.status: creating rtems_gdb/Makefile
config.status: creating rgdb_specs/Makefile
config.status: creating relnotes/Makefile
config.status: creating new_chapters/Makefile
config.status: creating supplements/Makefile
config.status: creating supplements/arm/Makefile
config.status: creating supplements/c4x/Makefile
config.status: creating supplements/hppa1_1/Makefile
config.status: creating supplements/i386/Makefile
config.status: creating supplements/i960/Makefile
config.status: creating supplements/m68k/Makefile
config.status: creating supplements/mips/Makefile
config.status: creating supplements/mips64orion/Makefile
config.status: creating supplements/powerpc/Makefile
config.status: creating supplements/sh/Makefile
config.status: creating supplements/sparc/Makefile
config.status: creating supplements/template/Makefile
config.status: creating gnu_docs/Makefile
configure: configuring in tools
'../../../rtems/doc/tools/configure' --prefix=/opt/rtems-4.7
--cache-file=/dev/null --srcdir=../../../rtems/doc/tools
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for strdup... yes
checking for strstr... yes
config.status: creating bmenu/Makefile
config.status: creating texi2www/Makefile
configure: configuring in i386-rtems/c
configure: running /usr/local/bin/bash '../../../rtems/c/configure'
'--prefix=/opt/rtems-4.7' '--host=i386-rtems'
'--build=i386-unknown-freebsd4.7' '--target=i386-rtems'
'--with-target-subdir=i386-rtems'
'--exec-prefix=/opt/rtems-4.7/i386-rtems' '--cache-file=/dev/null'
'--srcdir=../../../rtems/c'
checking host system type... i386-pc-rtems
checking for i386-rtems-strip... i386-rtems-strip
Makefiles... no
checking if cpu i386 is supported... yes
checking for make/custom/pc386.cfg... yes
target architecture: i386.
available BSPs: pc386.
'gmake all' will build the following BSPs: pc386.
other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
config.status: creating make/Makefile
config.status: creating make/custom/Makefile
[162] gmake all
Making all in make
gmake[1]: Entering directory `/usr/home/ctuffli/dev/rtems/build/make'
Making all in custom
gmake[2]: Entering directory
`/usr/home/ctuffli/dev/rtems/build/make/custom'
gmake[2]: Nothing to be done for `all'.
gmake[2]: Leaving directory
gmake[2]: Entering directory `/usr/home/ctuffli/dev/rtems/build/make'
gmake[2]: Nothing to be done for `all-am'.
gmake[2]: Leaving directory `/usr/home/ctuffli/dev/rtems/build/make'
gmake[1]: Leaving directory `/usr/home/ctuffli/dev/rtems/build/make'
gmake[1]: Entering directory `/usr/home/ctuffli/dev/rtems/build'
gmake[1]: Nothing to be done for `all-am'.
gmake[1]: Leaving directory `/usr/home/ctuffli/dev/rtems/build'
Chuck Tuffli
Agilent Technologies
