problem building from CVS on FreeBSD
Ralf Corsepius corsepiu at faw.uni-ulm.de
Sun Aug 31 14:36:35 UTC 2003
On Sun, 2003-08-31 at 15:51, chuck_tuffli at agilent.com wrote:
> I'm trying to build RTEMS from the CVS head and am running into some
> pretty basic problems. The host system is an x86 running FreeBSD 4.7
> with autoconf 2.57 and automake 1.7 from ports.
> After running configure and 'gmake all', I get the output below. Any
> ideas why I get the messages about "Nothing to be done"?
Because, make descended into a directory and detected that there is
nothing to do for it. This is normal, and there is nothing wrong with it
(cf. below)
> [161] AUTOCONF="autoconf257" AUTOHEADER="autoheader257"
> AUTOM4TE="autom4te257" AUTOMAKE="automake17" ACLOCAL="aclocal17"
> ../rtems/configure --target=i386-rtems --enable-docs
> --enable-rtemsbsp=pc386
> configure: creating ./config.status
> config.status: creating Makefile
> target architecture: i386.
> available BSPs: pc386.
> 'gmake all' will build the following BSPs: pc386.
> other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
This is the message you seem to have missed (cf. below).
> config.status: creating make/Makefile
> config.status: creating make/custom/Makefile
> [162] gmake all
> Making all in make
> gmake[1]: Entering directory `/usr/home/ctuffli/dev/rtems/build/make'
> Making all in custom
> gmake[2]: Entering directory
> `/usr/home/ctuffli/dev/rtems/build/make/custom'
> gmake[2]: Nothing to be done for `all'.
> gmake[2]: Leaving directory
> gmake[2]: Entering directory `/usr/home/ctuffli/dev/rtems/build/make'
> gmake[2]: Nothing to be done for `all-am'.
> gmake[2]: Leaving directory `/usr/home/ctuffli/dev/rtems/build/make'
> gmake[1]: Leaving directory `/usr/home/ctuffli/dev/rtems/build/make'
> gmake[1]: Entering directory `/usr/home/ctuffli/dev/rtems/build'
> gmake[1]: Nothing to be done for `all-am'.
> gmake[1]: Leaving directory `/usr/home/ctuffli/dev/rtems/build'
Now, just enter "gmake" or gmake RTEMS_BSP=pc386
But, attention: You have checked out the CVS trunk, which currently
contains the current unstable development version of RTEMS.
It basically should be buildable and functional, but things can be
pretty volatile, can change rapidly and unexpectedly.
For the stable version, which is far less volatile than CVS-trunk, you
can check out the rtems-4-6-branch (cvs co -rrtems-4-6-branch).
Ralf
