Error During Make for i386ex BSP - Beginner HELP
Aditya
avpenu at essex.ac.uk
Wed Aug 13 03:07:52 UTC 2003
Dear RTEMS users....
Im giving complete details on myproblem...
I use Mandrake 9.1 as the OS and the RTEMS BSP I require is for i386ex
The rpm files used for installing RTEMS cross compiler set are..
rtems-base-binutils-2.9.5.0.24-1.i386.rpm
rtems-base-gcc-gcc2.95.2newlib1.8.2-7.i386.r
rtems-base-gdb-4.18-4.i386.rpm
i386-rtems-binutils-2.9.5.0.24-1.i386.rpm
i386-rtems-gcc-gcc2.95.2newlib1.8.2-7.i386.r
i386-rtems-gdb-4.18-4.i386.rpm
After installing the RTEMS logging in as root using the command
rpm -i ..........i386.rpm
for all the RPM's above..
my archive directory is where rtems-4.5.0.tgz (rtems source)exists...
i go to the tools directory...and do....
$tar xzf ../archive/rtems-4.5.0.tgz
and a directory by name rtems-4.5.0 is created
-> in my tools directory -> i run the command
$export PATH=$PATH:/opt/rtems/bin
then
$mkdir build
$cd build
and then it follows as below....
[aditya at localhost build]$ ../rtems-4.5.0/configure --target=i386-rtems
--disable-posix --disable-tcpip --disable-cxx --enable-rtemsbsp=i386ex
--prefix=/opt/rtems
creating ./config.status
creating Makefile
creating target.cfg
target architecture: i386.
available BSPs: i386ex.
'make all' will build the following BSPs: i386ex.
other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
[aditya at localhost build]$ make RTEMS_BSP=i386ex
mkdir o-optimize
rm -f o-optimize/libtest.a
/opt/rtems/i386-rtems/bin/ar ruv o-optimize/libtest.a
../stubdr/o-optimize/stubdr.rel
a - ../stubdr/o-optimize/stubdr.rel
/opt/rtems/i386-rtems/bin/ranlib o-optimize/libtest.a
/usr/bin/install -c -m 644 o-optimize/libtest.a
../../../../../../i386ex/lib/libtest.a
make[5]: Leaving directory
`/home/aditya/tools/build/i386-rtems/c/i386ex/tests/support/wrapup'
make[5]: Entering directory
`/home/aditya/tools/build/i386-rtems/c/i386ex/tests/support'
make[5]: Nothing to be done for `all-am'.
make[4]: Leaving directory
Making all in samples
make[4]: Entering directory
`/home/aditya/tools/build/i386-rtems/c/i386ex/tests/samples'
Making all in hello
`/home/aditya/tools/build/i386-rtems/c/i386ex/tests/samples/hello'
mkdir o-optimize
/opt/rtems/bin/i386-rtems-gcc --pipe -B../../../../../../i386ex/lib/
-specs bsp_specs -qrtems -g -Wall -ansi -fasm -c -O4 -o
o-optimize/init.o
../../../../../../../rtems-4.5.0/c/src/tests/samples/hello/init.c
-specs bsp_specs -qrtems -g -Wall -ansi -fasm -L
../../../../../../i386ex/lib -O4 -o o-optimize/hello.coff
o-optimize/init.o ../../../../../../i386ex/lib/no-dpmem.rel
../../../../../../i386ex/lib/no-event.rel
../../../../../../i386ex/lib/no-msg.rel
../../../../../../i386ex/lib/no-mp.rel
../../../../../../i386ex/lib/no-part.rel
../../../../../../i386ex/lib/no-signal.rel
../../../../../../i386ex/lib/no-timer.rel
../../../../../../i386ex/lib/no-rtmon.rel
/opt/rtems/i386-rtems/bin/ld:../../../../../../i386ex/lib/linkcmds:115:
parse error
collect2: ld returned 1 exit status
make[5]: *** [o-optimize/hello.exe] Error 1
make[4]: *** [all-recursive] Error 1
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
`/home/aditya/tools/build/i386-rtems/c/i386ex/tests'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
`/home/aditya/tools/build/i386-rtems/c/i386ex'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/aditya/tools/build/i386-rtems/c'
make: *** [all-recursive] Error 1
Am I doing going Wrong Anywhere...Please help...Im not able to
understand where iam going wrong..or am i using the wrong files?
Thank you very much
Regards
Aditya <http://privatewww.essex.ac.uk/~avpenu>
URL: <http://lists.rtems.org/pipermail/users/attachments/20030813/b7da6bf3/attachment-0001.html>
