MAKE ERRORS :-(( possibly caused by linker
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Aug 15 13:17:21 UTC 2003
Aditya wrote:
> Dear RTEMS users....
> I use Mandrake Linux 9.1 as the OS and the RTEMS BSP is for i386ex
> The rpm files used for installing RTEMS cross compiler set are..
> rtems-base-gdb-5.2-1.i386.rpm
> rtems-base-binutils-2.13.2.1-1.i386.rpm
> rtems-base-gcc-gcc3.2.3newlib1.11.0-4.i686.rpm
> i386-rtems-gdb-5.2-1.i386.rpm
> i386-rtems-binutils-2.13.2.1-1.i386.rpm
> i386-rtems-gcc-gcc3.2.3newlib1.11.0-4.i686.rpm
> my archive directory is where rtems-ss-20030703.tar.bz2 (rtems
> source)exists...
> i go to the tools directory...and do....
> $bzcat rtems-ss-20030703.tar.bz2 | tar xf -
> and a directory by name < rtems-ss-20030703 >is created
> -> in my tools directory -> i run the command
> $export PATH=$PATH:/opt/rtems/bin
> then
> $mkdir build-rtems
> $cd build-rtems
> and then it follows as below....
> $ ../rtems-ss-20030703/configure --target=i386-rtems --disable-posix
> --disable-tcpip --disable-cxx --enable-rtemsbsp=i386ex
> --prefix=/opt/rtems
> checking for gawk... gawk
> checking whether gmake sets $(MAKE)... yes
> checking for i386-rtems-strip... i386-rtems-strip
> checking whether to enable maintainer-specific portions of Makefiles...
> no
> checking if cpu i386 is supported... yes
> checking for make/custom/i386ex.cfg... yes
> configure: creating ./config.status
> config.status: creating Makefile
> target architecture: i386.
> available BSPs: i386ex.
> 'gmake all' will build the following BSPs: i386ex.
> other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
> config.status: creating make/Makefile
> config.status: creating make/custom/Makefile
> $ gmake RTEMS_BSP=i386ex
> mkdir o-optimize
> mkdir -p -- ../../../../../i386ex/tests
> i386-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../i386ex/lib/
> -specs bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src-tests-samples\"
> -DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\"
> -DPACKAGE_VERSION=\"ss-20030703\"
> -DPACKAGE_STRING=\"rtems-c-src-tests-samples\ ss-20030703\"
> -DPACKAGE_BUGREPORT=\"rtems-bugs at OARcorp.com\" -isystem
> ../../../../../i386ex/lib/include -msoft-float -O4 -g -Wall -ansi -fasm
> -o o-optimize/init.o -c
> ../../../../../../../rtems-ss-20030703/c/src/tests/samples/hello/init.c
> -specs bsp_specs -qrtems -msoft-float -O4 -g -Wall -ansi -fasm -o
> o-optimize/hello.coff o-optimize/init.o
> ../../../../../i386ex/lib/no-dpmem.rel
> ../../../../../i386ex/lib/no-event.rel
> ../../../../../i386ex/lib/no-msg.rel ../../../../../i386ex/lib/no-mp.rel
> ../../../../../i386ex/lib/no-part.rel
> ../../../../../i386ex/lib/no-signal.rel
> ../../../../../i386ex/lib/no-timer.rel
> ../../../../../i386ex/lib/no-rtmon.rel
> /opt/rtems/lib/gcc-lib/i386-rtems/3.2.3/../../../../i386-rtems/bin/ld:
> section .initial [03ff1620 -> 03ff1858] overlaps section .eh_frame
> [03ff1620 -> 03ff16df]
> collect2: ld returned 1 exit status
> gmake[5]: *** [o-optimize/hello.exe] Error 1
> May I know the cause of this Error and a way to rectify it...
I just committed a patch for this. It was tracked as PR 450 and
the patch is attached to it.
You may also want the patch for PR453 which lets the pppd sample
test link. The description says it was for the ts_386ex but
fixing 450 on the i386ex BSP, made this bug show up.
Go to http://www.rtems.com/cgi-bin/gnatsweb.pl
and login in as guest with the password guest.
Then view the PRs.
> Thank you very much
> Regards
> Aditya
joel at OARcorp.com On-Line Applications Research
