MVME2304 Exception 3
Paul D Jines
pjines at lsu.edu
Mon Aug 18 17:49:46 UTC 2003
gregory.menke wrote:
> Joel Sherrill writes:
> > Paul D Jines wrote:
> > > Hello -
> > > We are trying to run RTEMS on a MVME2304-0143
> > > and are experiencing Exception 3 errors. Any help or
> > > advice anyone could give would be greatly appreciated.
> Exception 3 is a mmu error. At least the motorla_shared powerpc bsp's
> use the mmu to create a flat memory model where accesses outside the
> range will throw this exception- null pointers, corrupt pointers that
> kind of thing.
> This suggests some kind of bsp error. Could the OP please post the
> register dump? Its often possible to find what was running when the
> exception is thrown, and is also helpful to know if it always happens
> in the same place.
Here is the output from the GeSys run:
PPC1-Bug>nbo
Network Booting from: DEC21140, Controller 0, Device 0
Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
Loading: epics/vme01/cexp/rtems-4.6.0pre4-SSRL_20030731-mvme2307.exe
Client IP Address = 192.168.100.40
Server IP Address = 192.168.100.20
Gateway IP Address = 192.168.100.1
Subnet IP Address Mask = 255.255.255.0
Boot File Name = epics/vme01/cexp/rtems-4.6.0
.exe
Argument File Name =
Network Boot File load in progress... To abort hit <BREAK>
Bytes Received =&906060, Bytes Loaded =&906060
Bytes/Second =&302020, Elapsed Time =3 Second(s)
Residual-Data Located at: $07F88000
Model: 000000000000000000000000000(e2)
Serial: MOT05CA697
Processor/Bus frequencies (Hz): 333362624/66671288
Time Base Divisor: 4000
Memory Size: 8000000
Original MSR: 3040
Original HID0: 82
Original R31: 0
PCI: Probing PCI hardware
RTEMS 4.x/PPC load:
Uncompressing the kernel...
Kernel at 0x00000000, size=0x1d6690
Initrd at 0x00000000, size=0x0
Residual data at 0x001d7000
Command line at 0x001de000
done
Now booting...
Welcome to rtems-4.6.0pre4(PowerPC/PowerPC 604/mvme2307) on MVME 2300
OpenPIC found at C1000000.
pci : Interrupt routing not available for this bsp
OpenPIC Version ? (2 CPUs and 17 IRQ sources) at 0xC1000000
OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 2
OpenPIC timer frequency is 8333647 Hz
Universe II PCI-VME bridge detected at 0xC1040000, IRQ 11
Universe Master Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
1: 0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
2: 0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
Universe Slave Ports:
0: 0xC0000000 0x07F80000 0x80000000 A32, Pgm, Dat, Sup, Usr
Overriding main IRQ line PCI info with 5
exception handler called for exception 3
Next PC or Address of fault = 130E84
Saved MSR = 3032
R0 = 0
R1 = 1D75E0
R2 = 0
R3 = 1DB690
R4 = 0
R5 = 7316000
R6 = A8180
R7 = 1D0000
R8 = 10000
R9 = 78C297
R10 = 7F7F208
R11 = 788000
R12 = 1FE
R13 = 1C1198
R14 = 0
R15 = 0
R16 = 0
R17 = 0
R18 = 0
R19 = 0
R20 = 0
R21 = 0
R22 = 3032
R23 = 1CE2C0
R24 = 1D4F18
R25 = 0
R26 = 1C0000
R27 = 0
R28 = 1D0000
R29 = 1D5138
R30 = 78C2970
R31 = 1DB690
CR = 44800042
CTR = 731600
XER = 20000000
LR = DB968
DAR = 788000
Stack Trace:
IP: 0x00130E84, LR: 0x000DB968
--^ 0x0011323C--^ 0x000A8180--^ 0x000A8688--^ 0x000C1658--^ 0x000A8124
--^ 0x0000321C
unrecoverable exception!!! Push reset button
The above is from a previous run. We just powered up
the crate to get a fresh dump. The first try we had
incorrect DHCP settings. The second run produced the
exception below (no guarantees it isn't because of
our st.sys file.... ). The third produced a crash
similar to the first, but a few registers were different.
These were:
R5 = 4FED000
R11 = 2AB1000
CTR = 4FED00
DAR = 2AB1000
Everything else was the same.
The second run produced this:
(first part the same)
dec21140 : found device 'dc1', bus 0x00, dev 0x0E, func 0x00
dec2114x : driver attached
dec2114x : driver tasks created
bodoetcp2c1_1i4nxi t:: 0u0s:i0n1g: AnFe:t0wAo:r5k5 :i2n3t e r fnaacmee
''ddcc1
io 11000, mem C1041000, int 10
Bootpc testing starting
bootpc hw address is 0:1:af:a:55:23
My ip address is 192.168.100.40
Domain Name Server is 130.39.3.5
Domain Name Server is 130.39.244.30
Domain Name Server is 130.39.254.5
Hostname is vme01
Ignoring BOOTP/DHCP option code 40
Time Server is 132.163.4.102
Time Server is 132.163.4.103
Time Server is 132.163.4.101
Domain name is camd.edu
Boot file is epics/vme01/cexp/rtems-4.6.0pre4-SSRL_20030731-mvme2307.exe
Subnet mask is 255.255.255.0
Server ip address is 192.168.100.20
Gateway ip address is 192.168.100.1
Log server ip address is 192.168.100.20
$Id: init.c,v 1.11 2003/04/24 02:02:25 till Exp $
Welcome to RTEMS GeSys
This system $Name: SSRL_RTEMS_20030731 $ was built on 20030731PDT18:01:13
Trying to synchronize NTP...OK
Installing TIOCGWINSZ line discipline: ok.
Change Dir to '/TFTP/BOOTP_HOST/epics/vme01/cexp/'
Trying symfile '/TFTP/BOOTP_HOST/epics/vme01/cexp/rtems-4.6.0
pre4-SSRL_20030731-
mvme2307.sym', system script 'st.sys'
Type 'cexp.help()' for help (no quotes)
'st.sys':
(text deleted)
printf("Hello World")
Hello World0x0000000b (11)
cexp.help()
int cexp (char* cmdline)
Cexp builtin routines are:
(more text deleted)
Type a C expression, e.g.
printf("hello %s\n","cruelworld" + 5)
0x00169894 (1480852)
§S<81>
T
Ce
exception
handl
Next PC or Address of fault = 108A60
Saved MSR = B032
R0 = 1746
R1 = 7F41938
R2 = 0
R3 = 6039C
R4 = 7F7F208
R5 = 0
R6 = 2C030000
R7 = 1D0000
R8 = 108A40
R9 = 1C0000
R10 = 7F46E40
R11 = 1B97F0
R12 = 0
R13 = 1C1198
R14 = 0
R15 = 0
R16 = 0
R17 = 0
R18 = 0
R19 = 0
R20 = 0
R21 = 0
R22 = 0
R23 = 1D4F18
R24 = 1C0000
R25 = 1D0000
R26 = 1C0000
R27 = 1C0000
R28 = 7F7C7A8
R29 = 1D4F18
R30 = 7F7F208
R31 = 1B1CA8
CR = 44242028
CTR = 108A40
XER = 0
LR = 113468
DAR = 6039C
Stack Trace:
IP: 0x00108A60, LR: 0x00113468
--^ 0x00113548--^ 0x000BF2EC--^ 0x00103CC8--^ 0x00110368--^ 0x00110484
--^ 0x000A8CE4--^ 0x000D2B44--^ 0x000C0028--^ 0x0011D72C--^ 0x0011D784
--^ 0x001363E4--^ 0x00124BA8--^ 0x00126550--^ 0x00126680--^ 0x0006039C
--^ 0x00060690--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0
--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0
Too many stack frames (stack possibly corrupted), giving up...
Thanks,
Paul
