MVME2304 Exception 3
Till Straumann strauman at SLAC.Stanford.EDU
Tue Aug 19 02:58:09 UTC 2003
Paul - at this point, I suspect a bug
in the page table code or corrupted page
tables. I rebuilt the GeSys/RTEMS application
with
  a) debugging for page tables enabled
  b) leave DBAT0 enabled, thus effectively
     shadowing the page tables.
Please download
( http://www.slac.stanford.edu/~strauman/rtems/gesys/ )
and test the 'gesys-paul.exe' and 'gesys-paul.sym'
binary + symfile.
Let me know
  a) if you still get the exception 3
  b) attach the usual log, please (everything
     printed to the console).
  c) if you get that far, try to dump the
     page table to a file and send that to me.
     1] create an empty, world writable file on your
        TFTP server, e.g.
          touch /tftpboot/pt-dump
          chmod a+w /tftpboot/pt-dump
     2] at the GeSys prompt, issue
          ptDump("/TFTP/BOOTP_HOST/pt-dump")
     3] ptDump also prints info -
        please let me know what it says...
Regards
-- Till
Paul D Jines wrote:
> gregory.menke wrote:
>>Joel Sherrill writes:
>>>Paul D Jines wrote:
>>>>Hello -
>>>>   We are trying to run RTEMS on a MVME2304-0143
>>>>and are experiencing Exception 3 errors.  Any help or
>>>>advice anyone could give would be greatly appreciated.
>>Exception 3 is a mmu error.  At least the motorla_shared powerpc bsp's
>>use the mmu to create a flat memory model where accesses outside the
>>range will throw this exception- null pointers, corrupt pointers that
>>kind of thing.
>>This suggests some kind of bsp error.  Could the OP please post the
>>register dump?  Its often possible to find what was running when the
>>exception is thrown, and is also helpful to know if it always happens
>>in the same place.
> Here is the output from the GeSys run:
> PPC1-Bug>nbo
> Network Booting from: DEC21140, Controller 0, Device 0
> Device Name: /pci at 80000000/pci1011,9 at e,0:0,0
> Loading: epics/vme01/cexp/rtems-4.6.0pre4-SSRL_20030731-mvme2307.exe
> Client IP Address      = 192.168.100.40
> Server IP Address      = 192.168.100.20
> Gateway IP Address     = 192.168.100.1
> Subnet IP Address Mask = 255.255.255.0
> Boot File Name         = epics/vme01/cexp/rtems-4.6.0
> .exe
> Argument File Name     =
> Network Boot File load in progress... To abort hit <BREAK>
> Bytes Received =&906060, Bytes Loaded =&906060
> Bytes/Second   =&302020, Elapsed Time =3 Second(s)
> Residual-Data Located at: $07F88000
> Model: 000000000000000000000000000(e2)
> Serial: MOT05CA697
> Processor/Bus frequencies (Hz): 333362624/66671288
> Time Base Divisor: 4000
> Memory Size: 8000000
> Original MSR: 3040
> Original HID0: 82
> Original R31: 0
> PCI: Probing PCI hardware
> RTEMS 4.x/PPC load:
> Uncompressing the kernel...
> Kernel at 0x00000000, size=0x1d6690
> Initrd at 0x00000000, size=0x0
> Residual data at 0x001d7000
> Command line at 0x001de000
> done
> Now booting...
> Welcome to rtems-4.6.0pre4(PowerPC/PowerPC 604/mvme2307) on MVME 2300
> OpenPIC found at C1000000.
> pci : Interrupt routing not available for this bsp
> OpenPIC Version ? (2 CPUs and 17 IRQ sources) at 0xC1000000
> OpenPIC Vendor 0 (Motorola), Device 0 (Raven), Stepping 2
> OpenPIC timer frequency is 8333647 Hz
> Universe II PCI-VME bridge detected at 0xC1040000, IRQ 11
> Universe Master Ports:
> Port  VME-Addr   Size       PCI-Adrs   Mode:
> 0:    0x20000000 0x0F000000 0x10000000 A32, Dat, Sup
> 1:    0x00000000 0x00FF0000 0x1F000000 A24, Dat, Sup
> 2:    0x00000000 0x00010000 0x1FFF0000 A16, Dat, Sup
> Universe Slave Ports:
> 0:    0xC0000000 0x07F80000 0x80000000 A32, Pgm, Dat, Sup, Usr
> Overriding main IRQ line PCI info with 5
> exception handler called for exception 3
>          Next PC or Address of fault = 130E84
>          Saved MSR = 3032
>          R0 = 0
>          R1 = 1D75E0
>          R2 = 0
>          R3 = 1DB690
>          R4 = 0
>          R5 = 7316000
>          R6 = A8180
>          R7 = 1D0000
>          R8 = 10000
>          R9 = 78C297
>          R10 = 7F7F208
>          R11 = 788000
>          R12 = 1FE
>          R13 = 1C1198
>          R14 = 0
>          R15 = 0
>          R16 = 0
>          R17 = 0
>          R18 = 0
>          R19 = 0
>          R20 = 0
>          R21 = 0
>          R22 = 3032
>          R23 = 1CE2C0
>          R24 = 1D4F18
>          R25 = 0
>          R26 = 1C0000
>          R27 = 0
>          R28 = 1D0000
>          R29 = 1D5138
>          R30 = 78C2970
>          R31 = 1DB690
>          CR = 44800042
>          CTR = 731600
>          XER = 20000000
>          LR = DB968
>          DAR = 788000
> Stack Trace:
>   IP: 0x00130E84, LR: 0x000DB968
> --^ 0x0011323C--^ 0x000A8180--^ 0x000A8688--^ 0x000C1658--^ 0x000A8124
> --^ 0x0000321C
> unrecoverable exception!!! Push reset button
> The above is from a previous run.  We just powered up
> the crate to get a fresh dump.  The first try we had
> incorrect DHCP settings.  The second run produced the
> exception below (no guarantees it isn't because of
> our st.sys file.... ).  The third produced a crash
> similar to the first, but a few registers were different.
> These were:
>           R5 = 4FED000
>           R11 = 2AB1000
>           CTR = 4FED00
>           DAR = 2AB1000
> Everything else was the same.
> The second run produced this:
> (first part the same)
> dec21140 : found device 'dc1', bus 0x00, dev 0x0E, func 0x00
> dec2114x : driver attached
> dec2114x : driver tasks created
> bodoetcp2c1_1i4nxi t::  0u0s:i0n1g: AnFe:t0wAo:r5k5 :i2n3t e r fnaacmee
> ''ddcc1
>   io 11000, mem C1041000, int 10
> Bootpc testing starting
> bootpc hw address is 0:1:af:a:55:23
> My ip address is 192.168.100.40
> Domain Name Server is 130.39.3.5
> Domain Name Server is 130.39.244.30
> Domain Name Server is 130.39.254.5
> Hostname is vme01
> Ignoring BOOTP/DHCP option code 40
> Time Server is 132.163.4.102
> Time Server is 132.163.4.103
> Time Server is 132.163.4.101
> Domain name is camd.edu
> Boot file is epics/vme01/cexp/rtems-4.6.0pre4-SSRL_20030731-mvme2307.exe
> Subnet mask is 255.255.255.0
> Server ip address is 192.168.100.20
> Gateway ip address is 192.168.100.1
> Log server ip address is 192.168.100.20
> $Id: init.c,v 1.11 2003/04/24 02:02:25 till Exp $
> Welcome to RTEMS GeSys
> This system $Name: SSRL_RTEMS_20030731 $ was built on 20030731PDT18:01:13
> Trying to synchronize NTP...OK
> Installing TIOCGWINSZ line discipline: ok.
> Change Dir to '/TFTP/BOOTP_HOST/epics/vme01/cexp/'
> Trying symfile '/TFTP/BOOTP_HOST/epics/vme01/cexp/rtems-4.6.0
> pre4-SSRL_20030731-
> mvme2307.sym', system script 'st.sys'
> Type 'cexp.help()' for help (no quotes)
> 'st.sys':
> (text deleted)
>   printf("Hello World")
> Hello World0x0000000b (11)
>   cexp.help()
>         int cexp (char* cmdline)
> Cexp builtin routines are:
> (more text deleted)
> Type a C expression, e.g.
>      printf("hello %s\n","cruelworld" + 5)
> 0x00169894 (1480852)
> n
> §S<81>
> T
> Ce
>        exception
> handl
>          Next PC or Address of fault = 108A60
>          Saved MSR = B032
>          R0 = 1746
>          R1 = 7F41938
>          R2 = 0
>          R3 = 6039C
>          R4 = 7F7F208
>          R5 = 0
>          R6 = 2C030000
>          R7 = 1D0000
>          R8 = 108A40
>          R9 = 1C0000
>          R10 = 7F46E40
>          R11 = 1B97F0
>          R12 = 0
>          R13 = 1C1198
>          R14 = 0
>          R15 = 0
>          R16 = 0
>          R17 = 0
>          R18 = 0
>          R19 = 0
>          R20 = 0
>          R21 = 0
>          R22 = 0
>          R23 = 1D4F18
>          R24 = 1C0000
>          R25 = 1D0000
>          R26 = 1C0000
>          R27 = 1C0000
>          R28 = 7F7C7A8
>          R29 = 1D4F18
>          R30 = 7F7F208
>          R31 = 1B1CA8
>          CR = 44242028
>          CTR = 108A40
>          XER = 0
>          LR = 113468
>          DAR = 6039C
> Stack Trace:
>   IP: 0x00108A60, LR: 0x00113468
> --^ 0x00113548--^ 0x000BF2EC--^ 0x00103CC8--^ 0x00110368--^ 0x00110484
> --^ 0x000A8CE4--^ 0x000D2B44--^ 0x000C0028--^ 0x0011D72C--^ 0x0011D784
> --^ 0x001363E4--^ 0x00124BA8--^ 0x00126550--^ 0x00126680--^ 0x0006039C
> --^ 0x00060690--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0
> --^ 0x000606E0--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0--^ 0x000606E0
> Too many stack frames (stack possibly corrupted), giving up...
> Thanks,
> Paul
