Intel X-Scale
Michael Kelly
mike at cogcomp.com
Wed Aug 20 20:30:04 UTC 2003
Brett,
Yes, the IXP4xx family uses the same core, but with ethernet
and PCI. I do not know if the other peripherals like serial are
the same as PXA255.
Michael
At 04:28 PM 8/20/2003, Brett Swimley wrote:
>Michael - Thanks for the response. I'll check out the website and educate myself a bit more.
>I think we're looking specifically at the IXP420 Network Processor,
>which (correct me if I'm wrong) would be similar to the PXA255 with different peripherals.
>Regards,
>Brett
>Michael Kelly wrote:
>>Brett,
>>Much solid work has already been done for ARM by OAR (Joel?) and
>>by Jay Monkman. The architecture work should be nearly 100%
>>the same as the MMU and cache models are identical. Obviously
>>there will be peripheral differences, but you can look at our boot
>>monitor (umon) source code for init and simple polled drivers for the
>>PXA255, serial, LCD and SDRAM. The link to the umon source is
>>on our web site (www.cogcomp.com). We are planning an RTEMS port
>>to our CSB352 PXA255 board, but it wouldn't ready be until Oct. or Nov.
>>Regards,
>>Michael
>>At 03:54 PM 8/20/2003, Brett Swimley wrote:
>>>Hi all,
>>>We're looking at several flavors of Intel X scale processors for possible use in upcoming projects and I'm just starting to familiarize myself with them. Do these processors have support and/or BSP's developed for RTEMS?
>>>I haven't done much research yet, but I get the indication that these are ARM processors....
>>>Regards,
>>>Brett Swimley
>>Michael J. Kelly
>>VP Engineering/Marketing
>>Cogent Computer Systems, Inc.
>>1130 Ten Rod Road
>>Suite A-201
>>North Kingstown, RI 02852
>>tel:401-295-6505 fax:401-295-6507
>>www.cogcomp.com
>>alternate email: mkelly6505 at hotmail.com
Michael J. Kelly
1130 Ten Rod Road
Suite A-201
www.cogcomp.com
