MIPS linker error for C++
Fri Aug 22 19:12:45 UTC 2003
mikeci at acm.org wrote:
>>This is amost certainly a linker script error.  Contrast your linkcmds
>>and bsp_spec with those on the Mongoose BSP- I know C++ & .init/.fini
>>works there.
>>Gregm
> Hi!
> I tried with Mongoose linkcmds and bsp_specs, but no luck. What I don't
> understand is how this _init and _fini symbols are defined. You have
> section .init and .fini in crtbegin.o but no symbols _init or _fini. They
> must be functions which call constructors or destructors, but they should
> be a nop for C. Is this right? I am using bsp_specs and linkcmds from
> P4000 BSP. I guess that this linker script file is correct? For now this
> linker error is not a problem, since I don't use C++, but I would like to
> resolve the problem with _init and _fini.
Are you linking with crtbegin.o, crtend.o, crti.o, and crtn.o
in your bsp_specs?
> Regards
> Ivica
