a strange problem with rtems_io_register_name
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Aug 29 13:00:17 UTC 2003
Stan wrote:
> ----- Original Message -----
> From: "Stan" <zylog at club-internet.fr>
> To: "Joel Sherrill" <joel.sherrill at OARcorp.com>
> Sent: Friday, August 29, 2003 2:38 PM
> Subject: Re: a strange problem with rtems_io_register_name
>>From: "Joel Sherrill" <joel.sherrill at OARcorp.com>
>>>Let's go back to basics then.
>>>What test are you running and have you modified it?
> In console.c, I have removed rtems_fatal_error_occurred called by
> rtems_io_register
> because io_register_name return RTEMS_TOOMANY.
> In fact, mknod fail with errno = ENOENT.
> In bspstart.c Cpu_table.postdriver_hook has been modified ( = NULL) for to
> avoid
> tests console ( stdout ).
> In test.c ("hello word") , I have added these lines in main task :
> status = rtems_io_register_name ("/dev/console", 0,0);
> if(status != RTEMS_SUCCESSFUL) rtems_fatal_error_occured(status);
/dev/console is already registered by the console device driver. The
error is indicating there is already a /dev/console. I am looking at
line 230 of console/console.c.
> status = rtems_io_register_name ("/dev/aux", 0,1);
> it return SUCCESSFUL.
/dev/aux was never registered before.
> I hope to become clearer ;)
> Stan
joel at OARcorp.com On-Line Applications Research
