Building RTEMS
Ralf Corsepius corsepiu at faw.uni-ulm.de
Mon Dec 1 12:31:51 UTC 2003
On Mon, 2003-12-01 at 03:35, Chris Sparks wrote:
> Hi,
> It has been quiet on this list for some time now....
> I managed to get a half decent Fedora up and running and was going
> through instructions to build
> RTEMS.  I am using the Getting started with the C++ users manual and I
> got several errors.
> The first was "checking for i386-gcc... no"
>  which I know I set the path right.
Well, though you say so, I doubt it.
> The second came from configure, "no acceptable cc found in $PATH
> So what is going on here?
Make sure to have
* the native toolchain installed
* the target toolchain installed
And to have set up $PATH correctly.
Ralf
