Motorola Coldfire delay() function
Wed Dec 3 14:08:29 UTC 2003
Charles Steaderman wrote:
> I have a custom board based upon the mcf5206e Coldfire processor. I
> based my custom bsp upon the excellent mcf5206elite bsp. I would like to
> use a delay() function to signal an error via leds if a fatal error
> occurs. There is a delay(microseconds) macro included with the
> mcf5206elite bsp, but the assembly instructions that it uses are for a
> full-blown M68K, not the Coldfire processor. The delay function is as
> follows:
> #define delay( microseconds ) \
>  { register rtems_unsigned32 _delay=(microseconds); \
>    register rtems_unsigned32 _tmp=123; \
>    asm volatile( "0: \
>                     nbcd      %0 ; \
>                     nbcd      %0 ; \
>                     dbf       %1,0b" \
>                  : "=d" (_tmp), "=d" (_delay) \
>                  : "0"  (_tmp), "1"  (_delay) ); \
> Does anyone know Coldfire assembly well enough to supply suitable,
> replacement instructions for "nbcd" and "dbf"?
Well since no one else is wading in...
This should be renamed to rtems_bsp_delay().  There was a sweep in Sept
2001 to rename them all to avoid such a common name.
On to how to implement it... it does not have to be an instruction loop.
It could poll a counter/timer register or whatever.  It could inline a
handful of NOPS or anything else as long as it kills time in microsecond
intervals.
> Thanks,
> - Charlie
