Building RTEMS
Chris Sparks mrada at catalina-inter.net
Thu Dec 4 11:58:24 UTC 2003
Hi all,
Ok I got this:
i386-rtems-gcc --pipe -DHAVE_CONFIG_H   -isystem
../../../.././pc586/lib/include -Isrc     -mcpu=pentium  -O4 -g -Wall
-o o-optimize/tcsetattr.o -c
../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcsetattr.c
-o o-optimize/tcdrain.o -c
../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcdrain.c
-o o-optimize/tcflow.o -c
../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcflow.c
-o o-optimize/tcflush.o -c
../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcflush.c
-o o-optimize/tcgetprgrp.o -c
../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/src/tcgetprgrp.c
i386-rtems-gcc: Internal error: Segmentation fault (program as)
Please submit a full bug report.
See <URL:http://gcc.gnu.org/bugs.html> for instructions.
gmake[4]: *** [o-optimize/tcgetprgrp.o] Error 1
gmake[4]: Leaving directory
`/usr/src/redhat/BUILD/build-rtems/i386-rtems/c/pc586/exec/libcsupport'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
`/usr/src/redhat/BUILD/build-rtems/i386-rtems/c/pc586/exec'
gmake[2]: *** [all-recursive] Error 1
Where do I go from here?
Chris Sparks wrote:
> Well I noticed that only the RTEMS part changed for pre5 and not the
> tools so I installed
> the patch to pre4 to make pre5 and my building seems to be progressing
> pretty nicely.
> I am getting excited that I am getting closer to my goal of getting a
> sample program to run.
> May not get to it until I get back from SIGAda conference this year.
> Is anyone going?  I'd
> like to swap RTEMS stories.
> Has anyone done any graphics (VGA, SVGA, whatever) with RTEMS?  I need
> it.
> Chris Sparks
> Chris Sparks wrote:
>> Ok I figured out what I did wrong and I was not passing the right
>> parameter into configure so
>> it couldn't find i386-rtems-gcc.  So I went ahead fixed my mistake
>> and the build still crashes.
>> It wants me to do a make dist-clean or some such action.
>> My question really is what specifically do I need to do to get up to
>> pre5.  I have pre4 and I
>> didn't want to have to download everything.  What exactly changed
>> that I need to upgrade to?
>> Thanks,
>> chris Sparks
>> Ralf Corsepius wrote:
>>> On Tue, 2003-12-02 at 07:26, Chris Sparks wrote:
>>>> Hello Ralf,
>>>>> On Mon, 2003-12-01 at 03:35, Chris Sparks wrote:
>>>>>> Hi,
>>>>>> It has been quiet on this list for some time now....
>>>>>> I managed to get a half decent Fedora up and running and was
>>>>>> going through instructions to build
>>>>>> RTEMS.  I am using the Getting started with the C++ users manual
>>>>>> and I got several errors.
>>>>>> The first was "checking for i386-gcc... no"
>>>>>> which I know I set the path right.
>>>>> Well, though you say so, I doubt it.
>>>> What is strange is that the native gcc is "gcc" not "i386-gcc" and
>>>> the target gcc is "i386-rtems-gcc" so
>>>> I don't know what this "i386-gcc" is.
>>> I don't know what you are doing ;-)
>>> The native C-compiler must be called cc or gcc and must be in $PATH
>>> which gcc
>>> should tell you if this applies.
>>>>>> The second came from configure, "no acceptable cc found in $PATH
>>>>>> So what is going on here?
>>>>> Make sure to have
>>>>> * the native toolchain installed
>>>>> * the target toolchain installed
>>>>> And to have set up $PATH correctly.
>>>> I have the "/opt/rtems/bin" before all others in my path.  Is this
>>>> wrong?
>>> It depends on which of the RTEMS toolchains you have installed.
>>> It could be one of these:
>>> /opt/rtems/bin (Used until now), /opt/rtems-4.6/bin (Probably used
>>> by the final 4.6-release) or
>>> /opt/rtems-4.7/bin (To be used by future snapshots).
>>> Assuming you want to build i386-rtems, you should have one of
>>> /opt/rtems/bin/i386-rtems-gcc
>>> /opt/rtems-4.6/bin/i386-rtems4.6-gcc
>>> /opt/rtems-4.7/bin/i386-rtems4.7-gcc
>>> Prepend the */bin to $PATH, that contains the i386-rtems*-gcc you have.
>>> Then configure RTEMS using the string that prefixes the target gcc
>>> you have:
>>> Eg. If having /opt/rtems/bin/i386-rtems-gcc, the  use
>>> configure --target=i386-rtems [options]
>>> If having /opt/rtems-4.6/bin/i386-rtems4.6-gcc, then use
>>> configure --target=i386-rtems4.6 [options]
>>> Ralf
