Building RTEMS
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Thu Dec 4 14:20:13 UTC 2003
Chris Sparks writes:
 > Well I noticed that only the RTEMS part changed for pre5 and not the
 > tools so I installed
 > the patch to pre4 to make pre5 and my building seems to be progressing
 > pretty nicely.
 > I am getting excited that I am getting closer to my goal of getting a
 > sample program to run.
 > May not get to it until I get back from SIGAda conference this year.  Is
 > anyone going?  I'd
 > like to swap RTEMS stories.
 > Has anyone done any graphics (VGA, SVGA, whatever) with RTEMS?  I need it.
Rosimildo Da Silva did a port of SVGAlib to RTEMS, but a quick check
of his project page shows its offline- at least from my workstation.
Joel might know where his page is, but I do have the tar.gz and diff
file if its not available elsewhere.  I was hoping to give a try at
porting it to PowerPC over the holidays, we have a cpci vga board
thats otherwise unused.  Its worth mentioning that it appears Mesa
OpenGL can use svgalib as a driver, so its not entirely impossible
that it could be ported to RTEMS too.  Interesting idea...
gregm
 > Chris Sparks
 > Chris Sparks wrote:
 > > Ok I figured out what I did wrong and I was not passing the right
 > > parameter into configure so
 > > it couldn't find i386-rtems-gcc.  So I went ahead fixed my mistake and
 > > the build still crashes.
 > > It wants me to do a make dist-clean or some such action.
 > > My question really is what specifically do I need to do to get up to
 > > pre5.  I have pre4 and I
 > > didn't want to have to download everything.  What exactly changed that
 > > I need to upgrade to?
 > > Thanks,
 > > chris Sparks
 > > Ralf Corsepius wrote:
 > >> On Tue, 2003-12-02 at 07:26, Chris Sparks wrote:
 > >>> Hello Ralf,
 > >>>> On Mon, 2003-12-01 at 03:35, Chris Sparks wrote:
 > >>>>> Hi,
 > >>>>> It has been quiet on this list for some time now....
 > >>>>> I managed to get a half decent Fedora up and running and was going
 > >>>>> through instructions to build
 > >>>>> RTEMS.  I am using the Getting started with the C++ users manual
 > >>>>> and I got several errors.
 > >>>>> The first was "checking for i386-gcc... no"
 > >>>>> which I know I set the path right.
 > >>>> Well, though you say so, I doubt it.
 > >>> What is strange is that the native gcc is "gcc" not "i386-gcc" and
 > >>> the target gcc is "i386-rtems-gcc" so
 > >>> I don't know what this "i386-gcc" is.
 > >> I don't know what you are doing ;-)
 > >> The native C-compiler must be called cc or gcc and must be in $PATH
 > >> which gcc
 > >> should tell you if this applies.
 > >>>>> The second came from configure, "no acceptable cc found in $PATH
 > >>>>> So what is going on here?
 > >>>> Make sure to have
 > >>>> * the native toolchain installed
 > >>>> * the target toolchain installed
 > >>>> And to have set up $PATH correctly.
 > >>> I have the "/opt/rtems/bin" before all others in my path.  Is this
 > >>> wrong?
 > >> It depends on which of the RTEMS toolchains you have installed.
 > >> It could be one of these:
 > >> /opt/rtems/bin (Used until now), /opt/rtems-4.6/bin (Probably used by
 > >> the final 4.6-release) or
 > >> /opt/rtems-4.7/bin (To be used by future snapshots).
 > >> Assuming you want to build i386-rtems, you should have one of
 > >> /opt/rtems/bin/i386-rtems-gcc
 > >> /opt/rtems-4.6/bin/i386-rtems4.6-gcc
 > >> /opt/rtems-4.7/bin/i386-rtems4.7-gcc
 > >> Prepend the */bin to $PATH, that contains the i386-rtems*-gcc you have.
 > >> Then configure RTEMS using the string that prefixes the target gcc
 > >> you have:
 > >> Eg. If having /opt/rtems/bin/i386-rtems-gcc, the  use
 > >> configure --target=i386-rtems [options]
 > >> If having /opt/rtems-4.6/bin/i386-rtems4.6-gcc, then use
 > >> configure --target=i386-rtems4.6 [options]
 > >> Ralf
