no-timer
Fabio Degiovanni - Eicas degiovanni at eicas.it
Tue Dec 9 10:13:52 UTC 2003
Dir Sir,
            I built RTEMS for ERC32 target with the commands:
configure --target=sparc-rtems
make RTEMS_BSP="erc32"
make install RTEMS_BSP="erc32"
Everything worked ok since now.
Now I want to use the timer functions, but I saw that the execution
stopped in rtems-4.5.0/c/src/exec/rtems/optman/no-timer.c. How can I
compile RTEMS enabling the timer functions?
In my application I put #define
CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER   and #define
CONFIGURE_MAXIMUM_TIMERS 1, so I presume that the problem is in the
configuration of RTEMS before building it.
Thnak you very much
Fabio Degiovanni
Dott. Ing. Degiovanni Fabio
Eicas Automazione
Via Vincenzo Vela, 27 10128 Torino (ITALIA)
Telefoni +39-11-562.37.98/562.3088 Fax +39-11-436.06.79
