flushing TCP socket
Eugene Denisov
dea at sendmail.ru
Wed Dec 10 12:13:58 UTC 2003
Hello all.
I'm get a problem with flushing stream socket. My network server is running
under RTEMS and mainly receive data, but rearly it has to send small packets
of data. The problem is the data comes to client with large delay (sometimes
more then 1 minute).
With VxWorks the problem was solved by setting following options
optval = 1;
setsockopt (sFd, IPPROTO_TCP, TCP_NODELAY, &optval, sizeof (optval));
setsockopt (sFd, SOL_SOCKET, SO_KEEPALIVE, &optval, sizeof (optval));
under UNIX the solution was using
fsync(sock_id)
unfortunately this does not get success in RTEMS.
