Problem with rtems_task_variable_delete
Till Straumann strauman at slac.stanford.edu
Wed Dec 10 19:05:02 UTC 2003
RTM (see below)
Dieter.B.Schaefer at t-online.de wrote:
>>On Tue, 09 Dec 2003 01:18:32 -0800 (PST), "Fernando RUIZ CASAS" wrote:
>>After browsing in the versions of sources the problem was fixed.
>>http://www.rtems.com/cgi-bin/cvsweb.cgi/rtems/cpukit/rtems/src/tasks.c.diff?r1=1.34&r2=1.35
>>In tasks.c the problem can be isolated again.
>> while (tvp) {
>>     next = tvp->next;
>>     if  (tvp->dtor)
>>         (*tvp->dtor)( tvp->ptr ); <<< HERE the change and the source of the problem.
>>     if (executing == deleted)
>>         *tvp->ptr = tvp->gval;
>>     _Workspace_Free( tvp );
>>Some printk let to show the dtor, the ptr, and more...
>>I can't test it. Sorry.
>Thank's for the hint. I had already modified this before. Unfortunately,
>it's not the solution. Here is what happens ...
>free(...) is called with the correct value
>|-> calles rtems_region_return_segment(...)
>                |-> calles _RTEMS_Lock_allocator()
>                                |-> calles _Internal_error_Occured(...)
>                                               |-> calles _BSP_Fatal_error(...)
>-> the end of the world.
>Any ideas, any hints from RTEMS professionals?
As I already pointed out: the task variable destructor is called from a
section of code which
is protected by 'disabling thread dispatching'. It is ILLEGAL to call
'free()' from such a section.
_CORE_mutex_Seize() (called indirectly by 'free()' when it acquires the
allocator lock)
detects the violation and raises 'Internal_error_Occurred()'.
PR#504 introduced this safeguard. Prior to PR504 everything would "work"
but the heap
was corrupted!
You must not use 'free' as a task variable dtor (or use the modified
'free()' I posted earlier
to work around this problem)
HTH
-- Till
PS: You guys might want to read the threads
         'Possible bug in _CORE_mutex_Seize()' discussed around 2003/9/30
       and
          'More heap corruption / allocator lock problems' discussed
aroung 2003/10/7
>BTW, did someone manage to run *all* spxx tests on a mbx8xx board
>successfully? Would be interesting to know if they all work with the
>unmodified BSP supplied in the source tree (rtems-4.6.0pre5)
>Regards
>Dieter Schaefer
