telnetd - printk for sparc/leon
Jerry Needell
jerry.needell at unh.edu
Thu Dec 11 15:15:17 UTC 2003
I am trying to use the telnetd daemon with the sparc/leon1 bsp
(4.6.0pre5) but get the following error:
[needell at needell telnet]$ make
sparc-rtems-gcc --pipe
-B/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/ -specs
bsp_specs -qrtems -g -Wall -O4 -g -mcpu=cypress -msoft-float
-c -o o-optimize/init.o init.c
In file included from init.c:49:
../networkconfig.h:70: warning: initialization from incompatible
pointer type
-o o-optimize/telnet.exe o-optimize/init.o
/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-dpmem.rel
/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-msg.rel
/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-mp.rel
/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-part.rel
/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-signal.rel
/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-timer.rel
/home/needell/leon/rtems/install/sparc-rtems/leon1/lib/no-rtmon.rel
librtemscpu.a(printk.o): In function `vprintk':
/home/needell/leon/rtems/build/b-rtems/sparc-rtems/c/leon1/exec/
libcsupport/../../../../../../rtems-4.6.0pre5/cpukit/libcsupport/src/
printk.c:142: undefined reference to `BSP_output_char'
..... many more of the same
I cannot find BSP_output_char defined for the sparc bsp. Any
suggestions as to what I am missing or doing wrong woulde be
appreciated.
From reading previous posting and the source code, it seemed like I
should be able to run the telnetd daemon by simply calling
main_telnetd(). This is my real goal, if anyone can tell me how to
start it, that would be appreciated too.
- thanks - Jerry
