Coldfire debug
Paul Whitfield paulw at microsol.iinet.net.au
Fri Dec 12 08:04:56 UTC 2003
silverio.di at qem.it wrote:
> Hi to all,
> this topic could be a little OT but I consider your great experience
> with GNU tools so I try to submit you that:
> I would debug a very little program in my Coldfire 5282 target,
> compiled with rtems m68k-rtems-gcc. What are the available ways to do that
> 1) exist a stub program to write in 5282 flash which permit debugging with
>     m68k-rtems-gdb debugger via serial cable ?
RTEMS 4.6.0 appears to have support for the gdb serial stub,
however I have not used it.
> 2) m68k-rtems-gdb support the coldfire BDM port ?
See:
http://sourceforge.net/projects/bdm/
For a version of GDB with bdm support that will work
with RTEMS.
Regards
Paul
