Coldfire debug
Fri Dec 12 12:12:00 UTC 2003
Paul Whitfield wrote:
> silverio.di at qem.it wrote:
>> Hi to all,
>> this topic could be a little OT but I consider your great experience
>> with GNU tools so I try to submit you that:
>> I would debug a very little program in my Coldfire 5282 target,
>> compiled with rtems m68k-rtems-gcc. What are the available ways to do
>> that
>> 1) exist a stub program to write in 5282 flash which permit debugging
>> with
>>     m68k-rtems-gdb debugger via serial cable ?
> RTEMS 4.6.0 appears to have support for the gdb serial stub,
> however I have not used it.
>> 2) m68k-rtems-gdb support the coldfire BDM port ?
> See:
> http://sourceforge.net/projects/bdm/
> For a version of GDB with bdm support that will work
> with RTEMS.
RTEMS makes no special assumptions with gdb so whatever gdb connects
to your target is OK.  Any BDM enabled version is what you want.
> Regards
> Paul
