Question about -ansi flag, and different size of struct from C and C++
Oleg Ivanov
Belinus at zelax.ru
Mon Dec 15 12:02:29 UTC 2003
Hello list,
I have a problem. I defined struct like:
struct dummy {
int var1;
short var2;
int var3;
} __attribute__ ((packed));
and access to it from C and C++ code.
The problem is that size from C is 10 bytes and from C++ is 12
bytes, I couldn't make that C++ packed that struct, exept removing -ansi
flag from compiler string.
So I have two question, is there another method to ask C++ packed
struct, and do we really need -ansi flag to compile rtems ?
Thanks
