How to figure out the file descriptor inside a driver?
Mon Dec 15 15:01:38 UTC 2003
Carl-Johan Hansson wrote:
> I'm writing a couple of new drivers and in one of them I want to map the
> file descriptor that I receive when I open the driver with another
> parameter when I call ioctl(). Is there some way to figure out the file
> descriptor when I'm inside the driver routine?
> Hope you understand the question!
Do you mean file description in the integer sense (e.g. read()) or
in the FILE * sense (e.g. fread())?
_________________________________________________________________
> Senaste nytt från motormarknaden http://motor.msn.se/
