RTEMS build problems
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Dec 19 09:29:46 UTC 2003
On Fri, 2003-12-19 at 07:14, Paul Cadaret wrote:
>   Joel,
> Thanks for the tip on running 'bootstrap'.  I must have missed that in
> the documentation.
> You mentioned that I need to have autoconf 2.59 and automake 1.8.  The
> 'README.configure'
> file says:
said ;)    T
> o re-generate auto*tool generated files (configure, Makefile.in
>     etc), autoconf-2.57 and automake-1.7.2 are required.
> Thanks for the tip on that as well.
Thanks for the report, I just updated this file ;)
>   That may explain my current Solaris
> "host-based" build problem.
Ralf
