m68k/mvme162 build problem on solaris-7
Paul Cadaret
rtems at usd.com
Mon Dec 29 06:47:25 UTC 2003
Hello,
I'm having trouble building RTEMS for a m68k-rtems target and a mvme162
bsp; something I thought would be
pretty stable.
My configure scipt is attached; The important part is:
export CC_FOR_BUILD=/tools/local/bin/gcc
export CXX_FOR_BUILD=/tools/local/bin/g++
export CC_FOR_HOST=/tools/local/bin/gcc
export CXX_FOR_HOST=/tools/local/bin/g++
export CC_FOR_TARGET=/tools/local.m68k-elf/bin/m68k-elf-gcc
export CXX_FOR_TARGET=/tools/local.m68k-elf/bin/m68k-elf-g++
${SHELL} ${SRCDIR}/configure \
--prefix=$LOCAL \
--target=m68k-rtems \
--program-prefix=m68k-elf- \
--disable-rtems-inlines \
--disable-posix \
--disable-networking \
--disable-cxx \
--enable-rtemsbsp="mvme162" \
where:
rtems> /tools/local/bin/gcc --version
2.95.2
This is my old reliable gcc for solaris
rtems> /tools/local.m68k-elf/bin/m68k-elf-gcc --version
m68k-elf-gcc (GCC) 3.4.0 20031224 (experimental)
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There
is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
rtems>
The above is a new m68k gcc cross compiler that seems to work (judged by
looking at the assembly code)
The error I see during the rtems build is:
809 configuring in tools
810 running /bin/ksh
../../../../../../../../../src/c/src/lib/libbsp/m68k/mvme162/tools/configure
'--prefix=/tools/local.rtems'
810 '--program-prefix=m68k-elf-' '--disable-rtems-inlines'
'--disable-posix' '--disable-networking' '--disable-cxx' '--with-tar
810 get-subdir=m68k-rtems'
'--exec-prefix=/tools/local.rtems/m68k-rtems'
'CC=/tools/local.m68k-elf/bin/m68k-elf-gcc' 'CXX=/tools
810 /local.m68k-elf/bin/m68k-elf-g++' 'RTEMS_BSP=mvme162'
'RTEMS_CPU_MODEL=m68040' 'RTEMS_BSP_FAMILY=mvme162' 'CPU_CFLAGS=-m6804
810 0' 'CFLAGS_OPTIMIZE_V=-O4 -fomit-frame-pointer'
--cache-file=/dev/null
--srcdir=../../../../../../../../../src/c/src/lib/lib
810 bsp/m68k/mvme162/tools
811 checking for gmake... gmake
812 checking for RTEMS Version... 4.6.0pre5
813 checking build system type... sparc-sun-solaris2.7
814 checking host system type... sparc-sun-solaris2.7
815 checking target system type... m68k-unknown-rtems
816 checking rtems target cpu... m68k
817 checking for a BSD-compatible install...
/tools/local/bin/install -c
818 checking whether build environment is sane... yes
819 checking for gawk... gawk
820 checking whether gmake sets $(MAKE)... yes
821 checking whether to enable maintainer-specific portions of
Makefiles... no
822 checking for sparc-sun-solaris2.7-gcc...
823 checking for C compiler default output... a.out
824 checking whether the C compiler works... configure: error:
cannot run C compiled programs.
825 If you meant to cross compile, use `--host'.
826 See `config.log' for more details.
827 config.status: error:
failed for tools
828 configure: error: /bin/ksh
'../../../../../../../../src/c/src/lib/libbsp/m68k/mvme162/configure'
failed for mvme162
829 configure: error: /bin/ksh
'../../../../../../../src/c/src/lib/libbsp/m68k/configure' failed
for m68k
830 configure: error: /bin/ksh
'../../../../../../src/c/src/lib/libbsp/configure' failed for lib/libbsp
831 gmake[2]: *** [mvme162] Error 1
832 gmake[2]: Leaving directory
`/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/rtems-4.6.0pre5/build.m68k-elf/m68k-rtems/c'
833 gmake[1]: *** [all-recursive] Error 1
834 gmake[1]: Leaving directory
835 make: *** [all-recursive] Error 1
Line-810 invokes a 'configure' that seems to be using my m68k-cross
compiler as if it were the solaris compiler.
I have verified that it compiles a small program (below) with the m68k
compiler and then dies when it can't
run the m68k binary on Solaris (so suprize there):
#line 2225 "configure"
/* confdefs.h. */
#define PACKAGE_NAME "rtems-c-src-lib-libbsp-m68k-mvme162-tools"
#define PACKAGE_TARNAME "rtems-c-src-lib-libbsp-m68k-mvme162-tools"
#define PACKAGE_VERSION "4.6.0pre5"
#define PACKAGE_STRING "rtems-c-src-lib-libbsp-m68k-mvme162-tools
4.6.0pre5"
#define PACKAGE_BUGREPORT "rtems-bugs at rtems.com"
/* end confdefs.h. */
int
main ()
return 0;
I could use some advice.
Thanks much.
Paul
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20031228/06ec6a78/attachment.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20031228/06ec6a78/attachment-0001.ksh>
Type: application/x-java-applet
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20031228/06ec6a78/attachment.bin>
