invalid variable name: build_alias
Ralf Corsepius corsepiu at faw.uni-ulm.de
Mon Dec 29 07:52:54 UTC 2003
On Tue, 2003-12-23 at 20:12, Scott Newell wrote:
> I'm also seeing the cygwin build_alias bug.
The last time this has been reported, the cause was the reporter having
had an environment variable named LIB set.
Make sure not to have set LIB.
>   I was able to get configure to
> complete by switching from --target=m68k-rtems to --target=m68k-elf-rtems
This doesn't make any sense, nor do I see how this is related to your
issue.
FYI: the canonicalization triple's meaning is <CPU>-<VENDOR>-<OS>
i.e.
m68k-rtems is equivalent to m68k-unknown-rtems (CPU=m68k,
VENDOR=unknown, OS=rtems)
m68k-elf-rtems would mean CPU=m68k, VENDOR=elf, OS=rtems.
VENDOR here means board/HW vendor/manufacturer. With RTEMS, this field
is not used, so the actual value is meaningless.
Ralf
