Some problems in the implement of the supercore:
Bert
doclzs at 21cn.com
Mon Dec 29 15:09:07 UTC 2003
Hi,here are some problems in the implement of the supercore.
i am urgent for your advice.
Thanks a lot in advance!
(1)the file "chain.inl"
RTEMS_INLINE_ROUTINE Chain_Node *_Chain_Head(
Chain_Control *the_chain
return (Chain_Node *) the_chain;
i think it should be:
return (Chain_Node *) the_chain->first;
one of my colleagues think it should be:
return (Chain_Node *) &the_chain->first;
who is right? after all, the variable "first" is already
a pointer to a Chain_Node.
(2)the file "coresem.inl"
RTEMS_INLINE_ROUTINE void _CORE_semaphore_Seize_isr_disable(
CORE_semaphore_Control *the_semaphore,
Objects_Id id,
boolean wait,
Watchdog_Interval timeout,
ISR_Level *level_p
Thread_Control *executing;
ISR_Level level = *level_p;
executing = _Thread_Executing;
executing->Wait.return_code = CORE_SEMAPHORE_STATUS_SUCCESSFUL;
if ( the_semaphore->count != 0 ) {
the_semaphore->count -= 1;
_ISR_Enable( level );
return;
if ( !wait ) {
executing->Wait.return_code = CORE_SEMAPHORE_STATUS_UNSATISFIED_NOWAIT;
return;
_Thread_Disable_dispatch();
_Thread_queue_Enter_critical_section( &the_semaphore->Wait_queue );
executing->Wait.queue = &the_semaphore->Wait_queue;
executing->Wait.id = id;
_Thread_queue_Enqueue( &the_semaphore->Wait_queue, timeout );
_Thread_Enable_dispatch();
Has it missed a piece of code "_ISR_Disable( level )"? if so,
where should it put?
(3)the file "heap.inl"
RTEMS_INLINE_ROUTINE Heap_Block *_Heap_User_block_at(
void *base
unsigned32 offset;
offset = *(((unsigned32 *) base) - 1);
return _Heap_Block_at( base, -offset + -HEAP_BLOCK_USED_OVERHEAD);
what is the function of this?
why "offset=*(((unsigned32 *) base) - 1)"?
what is meaning of the value "-offset + -HEAP_BLOCK_USED_OVERHEAD"?
(4)the file "heapallocate.c"
void *_Heap_Allocate(
Heap_Control *the_heap,
unsigned32 size
if ( size >= (-1 - HEAP_BLOCK_USED_OVERHEAD) )
return( NULL );
excess = size % the_heap->page_size;
the_size = size + the_heap->page_size + HEAP_BLOCK_USED_OVERHEAD;
It is sure that "size >= (-1 - HEAP_BLOCK_USED_OVERHEAD)", right?
what is meaning of the value "-1 - HEAP_BLOCK_USED_OVERHEAD"?
Is it necessary of the code
"the_size = size + the_heap->page_size + HEAP_BLOCK_USED_OVERHEAD;" ?
what is meaning of the value "the_heap->page_size + HEAP_BLOCK_USED_OVERHEAD"?
ÍæÓÎÏ·Ó®ÊýÂëÏà»ú¡¢MP3¡¢UÅÌ
http://mail.21cn.com/huodong/0310/
аÑÞ¾ªÈË ²¨°ÔÇǵ¤¡°°£¼°ÑÞºó¡±Ð´Õæ(ͼ)
http://news.21cn.com/huahua/
¹ã¶«ADSLÓû§ÓÐ×ÅÊý£¬21CNÉÌÎñÓÊÃâ·ÑÁì
ÃÀ¹úÂôÒùÊÀ¼Ò½ÒÃØ:Å®¶ù¼ËŮĸÀÏð±(ͼ)
http://news.21cn.com/social/
