invalid variable name: build_alias
Scott Newell newell at cei.net
Mon Dec 29 18:05:28 UTC 2003
>> I'm also seeing the cygwin build_alias bug.
>The last time this has been reported, the cause was the reporter having
>had an environment variable named LIB set.
>Make sure not to have set LIB.
"echo $LIB" shows that I do not have it set.
>>   I was able to get configure to
>> complete by switching from --target=m68k-rtems to --target=m68k-elf-rtems
>This doesn't make any sense, nor do I see how this is related to your
>issue.
I don't either, but I was in the mood to try _anything_, and the result was
different.
>FYI: the canonicalization triple's meaning is <CPU>-<VENDOR>-<OS>
>i.e.
>m68k-rtems is equivalent to m68k-unknown-rtems (CPU=m68k,
>VENDOR=unknown, OS=rtems)
>m68k-elf-rtems would mean CPU=m68k, VENDOR=elf, OS=rtems.
>VENDOR here means board/HW vendor/manufacturer. With RTEMS, this field
>is not used, so the actual value is meaningless.
Thanks.
newell
