m68k/mvme162 build problem on solaris-7
Paul Cadaret rtems at usd.com
Mon Dec 29 19:12:09 UTC 2003
Ralph,
Thanks for responding.
I tried to follow the documentation and build a m68k-rtems-gcc, but the
patch files described in the PDF
file were not on the web site.  See my post yesterday @ 2:08PM.   I had
built the m68k-elf-gcc as a test
case earlier and decided to try to build with it since I wasn't sure
what m68k-rtems-gcc was.
I would appreciate it if  you could point me to the diffs referenced in
the PDF file.  Then I should be able to
build m68k-rtems-gcc.
Thanks much.
Paul
Ralf Corsepius wrote:
>On Mon, 2003-12-29 at 07:47, Paul Cadaret wrote:
>>Hello,
>>I'm having trouble building RTEMS for a m68k-rtems target and a mvme162
>>bsp;  something I thought would be
>>pretty stable.
>>My configure scipt is attached;  The important part is:
>>      export   CC_FOR_BUILD=/tools/local/bin/gcc
>>      export  CXX_FOR_BUILD=/tools/local/bin/g++
>>      export    CC_FOR_HOST=/tools/local/bin/gcc
>>      export   CXX_FOR_HOST=/tools/local/bin/g++
>>      export  CC_FOR_TARGET=/tools/local.m68k-elf/bin/m68k-elf-gcc
>>      export CXX_FOR_TARGET=/tools/local.m68k-elf/bin/m68k-elf-g++
>>      ${SHELL}  ${SRCDIR}/configure                                 \
>>            --prefix=$LOCAL                                         \
>>            --target=m68k-rtems                                     \
>>            --program-prefix=m68k-elf-                              \
>>            --disable-rtems-inlines                                 \
>>            --disable-posix                                         \
>>            --disable-networking                                    \
>>            --disable-cxx                                           \
>>            --enable-rtemsbsp="mvme162"                             \
>export PATH=/tools/local/bin:/tools/local.m68k-elf/bin:$PATH
><path-to-rtems>/configure --target=m68k-rtems
>should automatically do what you want.
>Furthermore: Using a m68k-elf-gcc won't work with RTEMS.
>>where:
>>    rtems> /tools/local/bin/gcc --version
>>    2.95.2
>>This is my old reliable gcc for solaris
>This should be irrelevant. Any arbitrary cc is supposed to work here.
>>    rtems> /tools/local.m68k-elf/bin/m68k-elf-gcc --version
>>    m68k-elf-gcc (GCC) 3.4.0 20031224 (experimental)
>>    Copyright (C) 2003 Free Software Foundation, Inc.
>>    This is free software; see the source for copying conditions.  There
>>    is NO
>>    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
>>    PURPOSE.
>>    rtems>
>>The above is a new m68k gcc cross compiler that seems to work (judged by
>>looking at the assembly code)
>It will probably not work out of the box. m68k-rtems-gcc is not
>identical to m68k-elf-gcc.
>Ralf.
