Tool Chain
Ralf Corsepius corsepiu at faw.uni-ulm.de
Wed Dec 31 15:43:35 UTC 2003
On Wed, 2003-12-31 at 15:14, MEA-MikeFriedrichs wrote:
> Hello,
> I sent in an earlier inquiry, but say no response, perhaps my inquiring
> didn't get through the server links during these holidays.
> Anyway, I have MKS Tools installed on my machines.
> Everything I have seen recommends Cygwin to build RTEMS, but MKS is also
> POSIX compliant, so I was thinking either shell should work.
> Can I build RTEMS using MKS instead of Cygwin?
AFAICT, nobody has tried it before, so feel free to try it ;)
If you can manage to build the cross toolchains using MKS, I'd expect
you to also be able to build RTEMS.
[FWIW: MinGW is rumored to be able to build RTEMS.]
Ralf
