Problem with rtems_task_variable_delete
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Dec 9 12:00:04 UTC 2003
Fernando RUIZ CASAS wrote:
>On Tue, 09 Dec 2003 01:18:32 -0800 (PST), "Fernando RUIZ CASAS" wrote:
>>On Mon, 08 Dec 2003 22:58:15 +0100, Dieter Schaefer wrote:
>>Hi,
>> The same problem ago.
>> A patch has be submitted longtime ago to resolve this concern.
>> The problem is that a new implementation of core has been done.
>> The problem is in
>> /rtems/cpukit/rtems/src/taskvariabledelete.c
>> at line 59
>> _Workspace_free(tvp) needs be changed by
>> _Workspace_free(*tvp) perhaphs. (I can't test it,sorry)
>> It's a problem resolved but with the new implementation the problem arrives again.
>> A lot of mails have been interchanged with Joel to obtain a patch in the core.
>> BRGDS.
>> The author of rtems_telnetd.
>SORRY I'm wrong. SORRY again.
>After browsing in the versions of sources the problem was fixed.
>http://www.rtems.com/cgi-bin/cvsweb.cgi/rtems/cpukit/rtems/src/tasks.c.diff?r1=1.34&r2=1.35
>In tasks.c the problem can be isolated again.
> while (tvp) {
> next = tvp->next;
> if (tvp->dtor)
> (*tvp->dtor)( tvp->ptr ); <<< HERE the change and the source of the problem.
> if (executing == deleted)
> *tvp->ptr = tvp->gval;
> _Workspace_Free( tvp );
>Some printk let to show the dtor, the ptr, and more...
>I can't test it. Sorry.
The code above is the correct way to do it based upon the semantics of
other RTOS' that provide
per-task variables. Please (quickly) submit a patch for the shell code
that works with t his.
>>>Hello,
>>>trying to get telnetd to work (powerpc, rtems-4.6.0pre5) I experienced
>>>the following problem ...
>>>trying various commands everything seems to work Ok, until I try to
>>>logoff from the telnet session. The system crashes, mean end up
>>>in the BSP panic handler.
>>>Digging into the problem, it seems to be related with deleting a task variable.
>>>If the task variable contains a pointer to malloc'ed memory and 'free' is
>>>passed to rtems_task_variable_add it will crash on deleting the task.
>>>Background: telnetd uses shell, and shell creates a 'user environment'
>>>after issuing a 'logoff', shell tries to execute a
>>>rtems_task_delete( RTEMS_SELF );
>>>which in turn, at some point calls
>>>rtems_task_variable_delete(RTEMS_SELF, ... );
>>>The same behavior can be reproduces with a slightly modified version
>>>of 'ticker test'
>>>Adding a task variable pointing to malloc'ed space, assign different values
>>>etc. and deleting this space manually after 'rtems_task_variable_delete'
>>>everything works Ok. Passing 'free' to automatically delete this space, it
>>>ends up in the BSP panic handler.
>>>Did anybody experienced the same/similar problem? Or, even better,
>>>has a fix or work-around?
>>>Any information or hint is appreciated.
>>>Thanks
>>>Dieter Schaefer
>>>PS: FTP and Web-Server runs all day long even under heavy load and
>>>with continuous ping on FEC and SCCx.
>>FTP calls chroot() and chroot() builds a nes user environment the same way that telnetd.
>>but FTPD runs forever.
