HELP: Installing RTEMS rpms in i86... Errors...
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Dec 11 11:56:37 UTC 2003
Alex wrote:
>Hi all...
>I am trying to install RTEMS 4.2 rpms in a intel x86
>First I did this:
>rpm -i rtems-4.6-i386-rtems-binutils-2.13.2.1-1.i686.rpm
>rpm -i rtems-4.6-i386-rtems-gcc-gcc3.2.3newlib1.11.0-1.i686.rpm
>rpm -i rtems-4.6-i386-rtems-gdb-5.2-1.i686.rpm
>rpm -i rtems-4.6-rtems-base-binutils-2.13.2.1-1.i386.rpm
>rpm -i rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-1.i686.rpm
>rpm -i rtems-4.6-rtems-base-gdb-5.2-1.i686.rpm
>The installation was made to /opt/rtems
>Then I changed the /etc/profile
>PATH=/opt/rtems-4.6/bin:$PATH
>restart system
>.Crate folder tools inside /opt/rtems-4.6
>.cd tools
>.copy the following files to tools folder
>examples-4.6.0pre5.tar.bz2
>rtems-4.6.0pre5.tar.bz2
>Then I extract files from the bz2 files using the Ark app
>Then:
>Build do RTEMS
>.Inside tools I created a folder called build
>.cd build
>.then I executed the following commnand to configure, compile and install rtems to i86
>/opt/rtems-4.6/tools/rtems-4.6.0pre5/configure -- target=i386-rtems --enable-rdbg
>--enable-tests --enable-multiprocessing --enable-rtemsbsp=i386-rtems --prefix=/opt/rtems-4.6
You used --enable-rtemsbsp=i386-rtems. The right hand side of that =
should be a BSP name
like pc386, pc486, i386ex, etc.
Also you don't normally unarchive the source at the install point but in
another distinct working
directory.
>The following output was generated:
>checking for gmake... gmake
>checking for RTEMS Version... 4.6.0pre5
>checking build system type... i686-pc-linux-gnu
>checking host system type... i686-pc-linux-gnu
>checking target system type... i386-pc-rtems
>checking for a BSD-compatible install... /usr/bin/install -c
>checking whether build environment is sane... yes
>checking for gawk... gawk
>checking whether gmake sets $(MAKE)... yes
>checking whether to enable maintainer-specific portions of Makefiles... no
>checking if the test suites are enabled? ... yes
>configure: creating ./config.status
>configure: configuring in ./tools/build
>configure: running /bin/sh '/opt/rtems-4.6/tools/rtems-4.6.0pre5/tools/build/configure' '--prefix=/opt/rtems-4.6' '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu' '--enable-rdbg' '--enable-tests' '--enable-multiprocessing' '--enable-rtemsbsp=i386-rtems' '--target=i386-rtems' '--cache-file=/dev/null' '--srcdir=/opt/rtems-4.6/tools/rtems-4.6.0pre5/tools/build'
>checking for i686-pc-linux-gnu-gcc... no
>checking for gcc... gcc
>checking for C compiler default output... a.out
>checking whether the C compiler works... yes
>checking whether we are cross compiling... no
>checking for suffix of executables...
>checking for suffix of object files... o
>checking whether we are using the GNU C compiler... yes
>checking whether gcc accepts -g... yes
>checking for gcc option to accept ANSI C... none needed
>checking for style of include used by gmake... GNU
>checking dependency style of gcc... gcc3
>checking how to run the C preprocessor... gcc -E
>checking for egrep... grep -E
>checking for ANSI C header files... yes
>checking for sys/types.h... yes
>checking for sys/stat.h... yes
>checking for stdlib.h... yes
>checking for string.h... yes
>checking for memory.h... yes
>checking for strings.h... yes
>checking for inttypes.h... yes
>checking for stdint.h... yes
>checking for unistd.h... yes
>checking getopt.h usability... yes
>checking getopt.h presence... yes
>checking for getopt.h... yes
>checking for strerror... yes
>checking for strtol... yes
>checking for bash... /bin/bash
>config.status: creating Makefile
>config.status: creating install-if-change
>config.status: creating config.h
>config.status: executing depfiles commands
>configure: configuring in ./tools/cpu
>configure: running /bin/sh '/opt/rtems-4.6/tools/rtems-4.6.0pre5/tools/cpu/configure' '--prefix=/opt/rtems-4.6' '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu' '--enable-rdbg' '--enable-tests' '--enable-multiprocessing' '--enable-rtemsbsp=i386-rtems' '--target=i386-rtems' '--cache-file=/dev/null' '--srcdir=/opt/rtems-4.6/tools/rtems-4.6.0pre5/tools/cpu'
>checking rtems target cpu... i386
>configure: configuring in generic
>configure: running /bin/sh '/opt/rtems-4.6/tools/rtems-4.6.0pre5/tools/cpu/generic/configure' --prefix=/opt/rtems-4.6 '--prefix=/opt/rtems-4.6' '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu' '--enable-rdbg' '--enable-tests' '--enable-multiprocessing' '--enable-rtemsbsp=i386-rtems' '--target=i386-rtems' '--cache-file=/dev/null' '--srcdir=/opt/rtems-4.6/tools/rtems-4.6.0pre5/tools/cpu' 'build_alias=i686-pc-linux-gnu' 'host_alias=i686-pc-linux-gnu' 'target_alias=i386-rtems' --cache-file=/dev/null --srcdir=/opt/rtems-4.6/tools/rtems-4.6.0pre5/tools/cpu/generic
>config.status: creating size_rtems
>configure: configuring in i386-rtems/c
>configure: running /bin/sh '/opt/rtems-4.6/tools/rtems-4.6.0pre5/c/configure' '--prefix=/opt/rtems-4.6' '--host=i386-rtems' '--build=i686-pc-linux-gnu' '--target=i386-rtems' '--enable-rdbg' '--enable-tests' '--enable-multiprocessing' '--enable-rtemsbsp=i386-rtems' '--with-target-subdir=i386-rtems' '--exec-prefix=/opt/rtems-4.6/i386-rtems' '--cache-file=/dev/null' '--srcdir=/opt/rtems-4.6/tools/rtems-4.6.0pre5/c'
>checking host system type... i386-pc-rtems
>checking for i386-rtems-strip... i386-rtems-strip
>checking if cpu i386 is supported... yes
>checking for make/custom/i386-rtems.cfg...
>configure: error: no
>configure: error: /bin/sh '/opt/rtems-4.6/tools/rtems-4.60pre/c/configure' failed for c
>After this inside the direcory /usr/src/RTEMS/Sources/
>a directory called i386-rtems was created with another directory inside called c with the following log inside a file called config.log
>(/usr/src/RTEMS/Sources/i386-rtems/c/config.log)
>contents of the config.log file:
>This file contains any messages produced by compilers while
>running configure, to aid debugging if configure makes a mistake.
>It was created by rtems-c configure 4.6.0pre5, which was
>generated by GNU Autoconf 2.57. Invocation command line was
> $ /opt/rtems-4.6/tools/rtems-4.6.0pre5/c/configure --prefix=/opt/rtems-4.6 --host=i386-rtems --build=i686-pc-linux-gnu --target=i386-rtems --enable-rdbg --enable-tests --enable-multiprocessing --enable-rtemsbsp=i386-rtems --with-target-subdir=i386-rtems --exec-prefix=/opt/rtems-4.6/i386-rtems --cache-file=/dev/null --srcdir=/opt/rtems-4.6/tools/rtems-4.6.0pre5/c
>## Platform. ##
>hostname = localhost
>uname -m = i686
>uname -r = 2.4.21-0.13mdk
>uname -s = Linux
>uname -v = #1 Fri Mar 14 15:08:06 EST 2003
>/usr/bin/uname -p = unknown
>/bin/uname -X = unknown
>/bin/arch = i686
>/usr/bin/arch -k = unknown
>/usr/convex/getsysinfo = unknown
>hostinfo = unknown
>/bin/machine = unknown
>/usr/bin/oslevel = unknown
>/bin/universe = unknown
>PATH: /opt/rtems-4.6/bin
>PATH: /sbin
>PATH: /usr/sbin
>PATH: /bin
>PATH: /usr/bin
>PATH: /usr/X11R6/bin
>PATH: /usr/local/bin
>PATH: /usr/local/sbin
>## Core tests. ##
>configure:1254: checking for gmake
>configure:1270: found /usr/bin/gmake
>configure:1280: result: gmake
>configure:1315: checking for RTEMS Version
>configure:1325: result: 4.6.0pre5
>configure:1335: checking build system type
>configure:1353: result: i686-pc-linux-gnu
>configure:1361: checking host system type
>configure:1375: result: i386-pc-rtems
>configure:1384: checking target system type
>configure:1398: result: i386-pc-rtems
>configure:1412: checking rtems target cpu
>configure:1439: result: i386
>configure:1456: checking for a BSD-compatible install
>configure:1510: result: /usr/bin/install -c
>configure:1521: checking whether build environment is sane
>configure:1564: result: yes
>configure:1597: checking for gawk
>configure:1613: found /bin/gawk
>configure:1623: result: gawk
>configure:1633: checking whether gmake sets $(MAKE)
>configure:1653: result: yes
>configure:1714: checking for i386-rtems-strip
>configure:1730: found /opt/rtems-4.6/bin/i386-rtems-strip
>configure:1740: result: i386-rtems-strip
>configure:1799: checking whether to enable maintainer-specific portions of Makefiles
>configure:1808: result: no
>configure:1868: checking if cpu i386 is supported
>configure:1872: result: yes
>configure:1938: checking for make/custom/i386-rtems.cfg
>configure:1944: error: no
>## Cache variables. ##
>ac_cv_build=i686-pc-linux-gnu
>ac_cv_build_alias=i686-pc-linux-gnu
>ac_cv_env_build_alias_set=set
>ac_cv_env_build_alias_value=i686-pc-linux-gnu
>ac_cv_env_host_alias_set=set
>ac_cv_env_host_alias_value=i386-rtems
>ac_cv_env_target_alias_set=set
>ac_cv_env_target_alias_value=i386-rtems
>ac_cv_host=i386-pc-rtems
>ac_cv_host_alias=i386-rtems
>ac_cv_path_install='/usr/bin/install -c'
>ac_cv_prog_AWK=gawk
>ac_cv_prog_MAKE=gmake
>ac_cv_prog_STRIP=i386-rtems-strip
>ac_cv_prog_make_gmake_set=yes
>ac_cv_target=i386-pc-rtems
>ac_cv_target_alias=i386-rtems
>## Output variables. ##
>ACLOCAL='${SHELL} /opt/rtems-4.6/tools/rtems-4.6.0pre5/missing --run aclocal-1.7'
>AMTAR='${SHELL} /opt/rtems-4.6/tools/rtems-4.6.0pre5/missing --run tar'
>AUTOCONF='${SHELL} /opt/rtems-4.6/tools/rtems-4.6.0pre5/missing --run autoconf'
>AUTOHEADER='${SHELL} /opt/rtems-4.6/tools/rtems-4.6.0pre5/missing --run autoheader'
>AUTOMAKE='${SHELL} /opt/rtems-4.6/tools/rtems-4.6.0pre5/missing --run automake-1.7'
>AWK='gawk'
>CYGPATH_W='echo'
>DEFS=''
>ECHO_C=''
>ECHO_N='-n'
>ECHO_T=''
>ENDIF='endif'
>INSTALL_DATA='${INSTALL} -m 644'
>INSTALL_PROGRAM='${INSTALL}'
>INSTALL_SCRIPT='${INSTALL}'
>INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
>LIBOBJS=''
>LIBS=''
>LTLIBOBJS=''
>MAINT='#'
>MAINTAINER_MODE_FALSE=''
>MAINTAINER_MODE_TRUE='#'
>MAKE='gmake'
>MAKEINFO='${SHELL} /opt/rtems-4.6/tools/rtems-4.6.0pre5/missing --run makeinfo'
>PACKAGE='rtems-c'
>PACKAGE_BUGREPORT='rtems-bugs at rtems.com'
>PACKAGE_NAME='rtems-c'
>PACKAGE_STRING='rtems-c 4.6.0pre5'
>PACKAGE_TARNAME='rtems-c'
>PACKAGE_VERSION='4.6.0pre5'
>PATH_SEPARATOR=':'
>PROJECT_ROOT='../$(top_builddir)'
>PROJECT_TOPdir='../../$(top_builddir)'
>RTEMS_BSP_LIST=''
>RTEMS_CPU='i386'
>RTEMS_HOST='rtems'
>RTEMS_TOPdir='..'
>SET_MAKE=''
>SHELL='/bin/sh'
>STRIP='i386-rtems-strip'
>VERSION='4.6.0pre5'
>ac_ct_STRIP=''
>bindir='${exec_prefix}/bin'
>build='i686-pc-linux-gnu'
>build_alias='i686-pc-linux-gnu'
>build_cpu='i686'
>build_os='linux-gnu'
>build_vendor='pc'
>datadir='${prefix}/share'
>exec_prefix='/opt/rtems-4.6/i386-rtems'
>host='i386-pc-rtems'
>host_alias='i386-rtems'
>host_cpu='i386'
>host_os='rtems'
>host_vendor='pc'
>includedir='${prefix}/include'
>infodir='${prefix}/info'
>install_sh='/opt/rtems-4.6/tools/rtems-4.6.0pre5/install-sh'
>libdir='${exec_prefix}/lib'
>libexecdir='${exec_prefix}/libexec'
>localstatedir='${prefix}/var'
>mandir='${prefix}/man'
>oldincludedir='/usr/include'
>prefix='/opt/rtems-4.6'
>program_transform_name='s,^,i386-rtems-,'
>rtems_bsp_configure=''
>sbindir='${exec_prefix}/sbin'
>sharedstatedir='${prefix}/com'
>sysconfdir='${prefix}/etc'
>target='i386-pc-rtems'
>target_alias='i386-rtems'
>target_cpu='i386'
>target_os='rtems'
>target_vendor='pc'
>## confdefs.h. ##
>#define PACKAGE_BUGREPORT "rtems-bugs at rtems.com"
>#define PACKAGE_NAME "rtems-c"
>#define PACKAGE_STRING "rtems-c 4.6.0pre5"
>#define PACKAGE_TARNAME "rtems-c"
>#define PACKAGE_VERSION "4.6.0pre5"
>configure: exit 1
>There is a problem configuring/compiling/installing the c directory... but why?
>Any ideas?
>Thanks a lot...
>Nuno Costa
