Question about -ansi flag, and different size of struct from C and C++
Oleg Ivanov
Belinus at zelax.ru
Mon Dec 15 14:18:01 UTC 2003
Thanks a lot!
Yes, I also see #pragma warning: ignoring pragma: even if I compiling
with or without -ansi flag.
And another thing, I compile code under two targets Motorola 68360
and 860.
In one point compiler aligned all struct to 4, in other every struct
member.
That mean size of struct
struct dummy {
int var1;
short var2;
int var3;
short var4;
on motorola 68360 will be 12 byte, and on 860 - 16 byte...
Is it also target dependent ?
