RTEMS build problems
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Mon Dec 22 07:13:36 UTC 2003
On Mon, 2003-12-22 at 00:55, Paul Cadaret wrote:
> Joel,
> The bootstrap process took a very long time to complete -- seemed like
> well over an hour.
Yes, running bootstrap is slow. One hour however indicates you using a
"not necessarily fast" machine.
> I'm trying to build the 'host-based' version on Solaris 7 now with the
> 2.59 autoconf & 1.8 automake
> in place. I'm seeing the same error as I saw before. Here's an extract:
> a - o-optimize/watchdogremove.o
> a - o-optimize/watchdogtickle.o
> a - o-optimize/wkspace.o
> ranlib o-optimize/libscore.a
> Making all in cpu
> Making all in unix
> gcc --pipe -DHAVE_CONFIG_H -I../../../../../.././posix/lib/include
> -DCPU_SYNC_IO -Dsolaris2 -O2 -g -Wall -o o-optimize/cpu.o -c
> ../../../../../../../c/src/../../cpukit/score/cpu/unix/cpu.c
> ../../../../../../../c/src/../../cpukit/score/cpu/unix/cpu.c:62:
> `FD_SETSIZE' undeclared here (not in a function)
> ../../../../../../../c/src/../../cpukit/score/cpu/unix/cpu.c:64:
> parse error before `sync_io_readfds'
> This error is caused by the fact that <sys/types.h> needs to see a
> definition of '__EXTENTIONS__' which will
> cause it to include <sys/select.h> where `FD_SETSIZE' lives. However, I
> am seeing a behavior I dont understand.
> Here's an exerpt from the script I created to run 'configure' in the
> 'build' subdir I createed.
> ${SHELL} ../configure \
> --prefix=$LOCAL \
> --enable-rtemsbsp="" \
> CFLAGS_FOR_BUILD=-D__EXTENSIONS__ \
> CXXFLAGS_FOR_BUILD=-D__EXTENSIONS__ \
> I specified this definition for the top-level configure, but it doesn't
> seem to be trickling down to the lower
> level makefile in
Use CFLAGS_FOR_TARGET instead of CFLAGS_FOR_BUILD or add
-D__EXTENSIONS__ to CPU_CFLAGS in make/custom/Solaris-posix.cfg.
> Am I correct in my understanding that I should be able to build a
> 'host-based' version on Solaris-7?
Theoretically yes, but you won't get far ..
Building unix/posix for Solaris2.7 rsp. SunOS5.7 is known to be broken
for quite a while and fixing it doesn't have a high priority.
For lucky circumstances, building unix/posix under Linux is not
affected, building under Cygwin is affected for some versions of Cygwin,
but not all.
Ralf
