RTEMS build problems
Paul Cadaret
rtems at usd.com
Mon Dec 22 18:17:13 UTC 2003
Ralph/Joel,
Thank you for responding.
You are right. My old 300MHz Ultra-10 is not fast... but it is very
reliable.
You mentioned that Solaris 2.7 is likely to be broken.
I may be able to setup a build environment on a solaris-9-sparc machine.
What are my chances getting the host-based version to build on a
solaris-9-sparc machine?
BTW: Just a note regarding my interest in RTEMS. I am familiar with
PSOS as I used it for a few
years many years ago. I remember when Motorola put out the RTEID spec
many years ago and I remembered
that RTEMS was based on that spec. I always thought that PSOS was a
very reasonable RTOS model and
I thought that I would see if I could get RTEMS running on an old
MVME162 I have. Since that time I
have worked on alot of other rtos based products using other rtos
environments.
As a 1st step I thought that I would just try to build the host-based
solaris version simply to provide a simple
compile-link-test environment to familiarize myself with the
environment. If any solaris host based
environment is likely to turn into a big science-project, let me know
and I'll stop and just move on to
the m68k/mvme162 bsp environment.
Thanks again.
Paul
Ralf Corsepius wrote:
>On Mon, 2003-12-22 at 00:55, Paul Cadaret wrote:
>>Joel,
>>The bootstrap process took a very long time to complete -- seemed like
>>well over an hour.
>Yes, running bootstrap is slow. One hour however indicates you using a
>"not necessarily fast" machine.
>>I'm trying to build the 'host-based' version on Solaris 7 now with the
>>2.59 autoconf & 1.8 automake
>>in place. I'm seeing the same error as I saw before. Here's an extract:
>> a - o-optimize/watchdogremove.o
>> a - o-optimize/watchdogtickle.o
>> a - o-optimize/wkspace.o
>> ranlib o-optimize/libscore.a
>> Making all in cpu
>> Making all in unix
>> gcc --pipe -DHAVE_CONFIG_H -I../../../../../.././posix/lib/include
>> -DCPU_SYNC_IO -Dsolaris2 -O2 -g -Wall -o o-optimize/cpu.o -c
>> ../../../../../../../c/src/../../cpukit/score/cpu/unix/cpu.c
>> ../../../../../../../c/src/../../cpukit/score/cpu/unix/cpu.c:62:
>> `FD_SETSIZE' undeclared here (not in a function)
>> ../../../../../../../c/src/../../cpukit/score/cpu/unix/cpu.c:64:
>> parse error before `sync_io_readfds'
>>This error is caused by the fact that <sys/types.h> needs to see a
>>definition of '__EXTENTIONS__' which will
>>cause it to include <sys/select.h> where `FD_SETSIZE' lives. However, I
>>am seeing a behavior I dont understand.
>>Here's an exerpt from the script I created to run 'configure' in the
>>'build' subdir I createed.
>> ${SHELL} ../configure \
>> --prefix=$LOCAL \
>> --enable-rtemsbsp="" \
>> CFLAGS_FOR_BUILD=-D__EXTENSIONS__ \
>> CXXFLAGS_FOR_BUILD=-D__EXTENSIONS__ \
>>I specified this definition for the top-level configure, but it doesn't
>>seem to be trickling down to the lower
>>level makefile in
>Use CFLAGS_FOR_TARGET instead of CFLAGS_FOR_BUILD or add
>-D__EXTENSIONS__ to CPU_CFLAGS in make/custom/Solaris-posix.cfg.
>>Am I correct in my understanding that I should be able to build a
>>'host-based' version on Solaris-7?
>Theoretically yes, but you won't get far ..
>Building unix/posix for Solaris2.7 rsp. SunOS5.7 is known to be broken
>for quite a while and fixing it doesn't have a high priority.
>For lucky circumstances, building unix/posix under Linux is not
>affected, building under Cygwin is affected for some versions of Cygwin,
>but not all.
>Ralf
