Binary is twice bigger
Leon Pollak
leonp at plris.com
Tue Dec 23 12:29:38 UTC 2003
On Tuesday 23 December 2003 14:11, you wrote:
> > On Tuesday 23 December 2003 12:24, you wrote:
> > > > Some time ago I ported one of my applications from RTEMS version
> > > > 4.0.3 (also ported to CodeWarrior in Windows) to RTEMS 4.6 (pre-last
> > > > snapshot) in Linux. I used the basic configuration (without
> > > > networking) with miniIMFS with RTEMS API and without any other
> > > > options (I hope so). I want to remind, that 4.0.3 RTEMS version was a
> > > > "pure" kernel version yet, without IMFS and Co. As the result, I can
> > > > compare the size of working binary in this 2 cases (both without
> > > > optimizations).
> > > > The size of Windows/CodeWarrior version is 173KB. The size of
> > > > GDB/Linux version is 349KB - twice bigger!!!
> Early this year we have ported RTEMS (MPC860 target) to MetroWerks
> CodeWarrior for Windows. There was a significant difference in size too.
> The 2 main reasons are:
> * CodeWarrior uses *real* EABI, not just some #defines in the Makefiles
Please, can you describe this a bit wider? What is real EABI and what is not?
> * The Linker does a real good job of dead-stripping code
Yes!!!
I checked the map for the routines I know 100% are not called and they are
still there!
But I am almost sure that there is some flag/option or something else, that
forces linker to remove the, no?
> And this had nothing to do with the C-Libraries, because we have used
> NewLib for our port.
A very interesting issue. My previous port to Metrowerks based on their run
time libraries. So, I thought that this has some influence.
> In case you are interested, we could go into more details.
I shall be glad if you have a bit of time.
> Best regards
> Dieter B. Schäfer
> - Managing Director -
> Schäfer Comtronic GmbH
> Robert Bosch Str. 7
> 64293 Darmstadt
> Tel: +49 6151 4286988
> Fax: +49 6151 4286990
> Email: Dieter.Schaefer at Schaefer-Comtronic.de
> Web: www.Schaefer-Comtronic.de
Dr.Leon M.Pollak
Director
PLR Information Systems Ltd.
leonp at plris dot com
