m68k-rtems-gcc toolchain build problem on Solaris-7
Paul Cadaret
rtems at usd.com
Tue Dec 30 16:33:46 UTC 2003
Joel ,
I listed a number of tools at the bottom of my post. I thought it would
be important. Here's an excerpt.
rtems> type gcc
gcc is /tools/local/bin/gcc
rtems> gcc --version
2.95.2
rtems>
Thanks.
Paul
Joel Sherrill wrote:
> What native compiler are you using?
> --joel
> Paul Cadaret wrote:
>> With help from Thomas (see below) I used the files he pointed out at
>> ftp://ftp.rtems.com/pub/rtems/releases/4.6.0pre5/tools
>> to run the build according to the PDF file at
>> http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0pre5/share/rtems/pdf/started.pdf
>> and I followed the PDF file instructions carefully for:
>> 4.1.2 Unarchiving the Tools
>> 4.1.3 Applying RTEMS Patches,
>> Apply RTEMS Patch to GCC,
>> Apply RTEMS Patch to binutils,
>> Apply RTEMS Patch to newlib
>> 4.1.4.2 Using configure and make,
>> Configuring and Building BINUTILS,
>> Configuring and Building GCC and NEWLIB
>> Binutils built and installed without error.
>> Building gcc-3.2.3 died as follows:
>> 1113
>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/xgcc
>> -B/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/
>> 1113 tools/gcc-3.2.3/build.m68k-rtems/gcc/ -nostdinc
>> -B/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/m
>> 1113 68k-rtems/newlib/ -isystem
>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/m68k-rtems/newlib/targ-i
>> 1113 nclude -isystem
>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/src/newlib/libc/include
>> -B/tools/local.m68k-rtems/m6
>> 1113 8k-rtems/bin/ -B/tools/local.m68k-rtems/m68k-rtems/lib/
>> -isystem /tools/local.m68k-rtems/m68k-rtems/include -O2 -I../../src/
>> 1113 gcc/../newlib/libc/sys/rtems/include -DIN_GCC
>> -DCROSS_COMPILE -W -Wall -Wwrite-strings -Wstrict-prototypes
>> -Wmissing-proto
>> 1113 types -isystem ./include -g -DHAVE_GTHR_DEFAULT
>> -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED -Dinhibit_libc -I. -I.
>> -I../../src/g
>> 1113 cc -I../../src/gcc/. -I../../src/gcc/config
>> -I../../src/gcc/../include -DL_floatdisf -c ../../src/gcc/libgcc2.c
>> -o libgcc/.
>> 1113 /_floatdisf.o
>> 1114
>> 1114 tools/gcc-3.2.3/build.m68k-rtems/gcc/ -nostdinc
>> 1114 68k-rtems/newlib/ -isystem
>> 1114 nclude -isystem
>> 1114 8k-rtems/bin/ -B/tools/local.m68k-rtems/m68k-rtems/lib/
>> 1114 gcc/../newlib/libc/sys/rtems/include -DIN_GCC
>> -Wmissing-proto
>> 1114 types -isystem ./include -g -DHAVE_GTHR_DEFAULT
>> -I../../src/g
>> 1114 cc -I../../src/gcc/. -I../../src/gcc/config
>> -I../../src/gcc/../include -DL_fixunsdfsi -c
>> ../../src/gcc/libgcc2.c -o libgcc/
>> 1114 ./_fixunsdfsi.o
>> 1115 In file included from
>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/include/syslimits.h:7,
>> 1116 from
>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/include/limits.h:11,
>> 1117 from ../../src/gcc/libgcc2.c:1166:
>> 1118
>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/include/limits.h:132:75:
>> no include path in whi
>> 1118 ch to find limits.h
>> 1119 make[2]: *** [libgcc/./_fixunsdfsi.o] Error 1
>> 1120 make[2]: Leaving directory
>> `/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc'
>> 1121 make[1]: *** [stmp-multilib] Error 2
>> 1122 make[1]: Leaving directory
>> 1123 make: *** [all-gcc] Error 2
>> ../../src/gcc/libgcc2.c looks like:
>> 1155 #ifdef L_fixunsdfsi
>> 1156 /* Reenable the normal types, in case limits.h needs
>> them. */
>> 1157 #undef char
>> 1158 #undef short
>> 1159 #undef int
>> 1160 #undef long
>> 1161 #undef unsigned
>> 1162 #undef float
>> 1163 #undef double
>> 1164 #undef MIN
>> 1165 #undef MAX
>> 1166 #include <limits.h> <<<============== OK
>> Note that ../src/gcc is where I unpacked the gcc-3.2.3 source tree and
>> applied the patches.
>> The above file includes ./gcc/include/limits.h:
>> 9 #ifndef _LIBC_LIMITS_H_
>> 10 /* Use "..." so that we find syslimits.h only in this same
>> directory. */
>> 11 #include "syslimits.h" <<<===============OK
>> 12 #endif
>> 13 #ifndef _LIMITS_H___
>> 14 #define _LIMITS_H___
>> The above file includes ./gcc/include/syslimits.h:
>> 1 /* syslimits.h stands for the system's own limits.h file.
>> 2 If we can use it ok unmodified, then we install this text.
>> 3 If fixincludes fixes it, then the fixed version is installed
>> 4 instead of this text. */
>> 5
>> 6 #define _GCC_NEXT_LIMITS_H /* tell gcc's limits.h
>> to recurse */
>> 7 #include_next <limits.h> <<<============= dies here searching
>> for a secondary instance of limits.h
>> 8 #undef _GCC_NEXT_LIMITS_H
>> What is "the system's own limits.h file" ??? linux? solaris? newlib?
>> rtems?
>> The "#include_next" is a feature of the newer gcc's
>> Disecting my build log line 1114 above looks like this:
>> -B/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/
>> -nostdinc \
>> -B/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/m68k-rtems/newlib/
>> -isystem
>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/m68k-rtems/newlib/targ-include
>> -isystem
>> -B/tools/local.m68k-rtems/m68k-rtems/bin/ \
>> -B/tools/local.m68k-rtems/m68k-rtems/lib/ \
>> -isystem /tools/local.m68k-rtems/m68k-rtems/include \
>> -O2 \
>> -I../../src/gcc/../newlib/libc/sys/rtems/include \
>> -DIN_GCC -DCROSS_COMPILE \
>> -Wmissing-prototypes \
>> -isystem ./include \
>> -g \
>> -DHAVE_GTHR_DEFAULT -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED
>> -Dinhibit_libc \
>> -I. \
>> -I. \
>> -I../../src/gcc \
>> -I../../src/gcc/. \
>> -I../../src/gcc/config \
>> -I../../src/gcc/../include \
>> -DL_fixunsdfsi \
>> -c \
>> ../../src/gcc/libgcc2.c \
>> -o libgcc/./_fixunsdfsi.o
>> From my build directory
>> (/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc)
>> if I run the command below
>> find .. ../../src /tools/local.m68k-rtems -follow -name limits.h
>> -print
>> shows the following:
>> find: ../gcc/cp/stage1: No such file or directory
>> find: ../gcc/cp/stage2: No such file or directory
>> find: ../gcc/cp/stage3: No such file or directory
>> find: ../gcc/cp/stage4: No such file or directory
>> ../gcc/cp/include/limits.h
>> find: ../gcc/fixinc/stage1: No such file or directory
>> find: ../gcc/fixinc/stage2: No such file or directory
>> find: ../gcc/fixinc/stage3: No such file or directory
>> find: ../gcc/fixinc/stage4: No such file or directory
>> ../gcc/fixinc/include/limits.h
>> ../gcc/include/limits.h
>> ../../src/gcc/fixinc/tests/base/sys/limits.h
>> ../../src/libstdc++-v3/config/cpu/generic/bits/limits.h
>> ../../src/libstdc++-v3/include/c_compatibility/limits.h
>> ../../src/libstdc++-v3/include/c_shadow/limits.h
>> ../../src/newlib/newlib/libc/include/limits.h
>> ../../src/newlib/newlib/libc/sys/linux/include/limits.h
>> ../../src/newlib/newlib/libc/sys/rtems/include/limits.h
>> ../../src/newlib/newlib/libc/sys/rtems/machine/limits.h
>> The above list shows --ALL-- of the instances of files named "limits.h"
>> available to this build; in fact, everything
>> that might possibly pertain to the RTEMS tool sources I downloaded.
>> The file "./include/limits.h" (aka ../gcc/include/limits.h) is the file
>> that xgcc finds on line 1166 above.
>> The file "syslimits.h" tries to use the "#include_next" mechanism to
>> find a secondary "limits.h", however,
>> the xgcc include path doesn't have any more files along the path. As
>> best I can determine the xgcc include path
>> should effectively be (from top to bottom):
>> ../../src/gcc
>> ./include
>> Since 'configure' builds the makefiles here and I have no idea what it
>> is trying to accomplish here, I really don't know
>> what to fix. As best I can tell the Solaris toolchain is broken.
>> Some further data:
>> rtems> uname -a
>> SunOS u2 5.7 Generic_106541-08 sun4u sparc
>> SUNW,UltraSPARC-IIi-Engine
>> rtems> perl --version
>> This is perl, v5.6.0 built for sun4-solaris
>> rtems> autoconf --version
>> autoconf (GNU Autoconf) 2.59
>> rtems> automake --version
>> automake (GNU automake) 1.8
>> rtems> gmake --version
>> GNU Make 3.80
>> 2.95.2
>> rtems> type m68k-rtems-as
>> m68k-rtems-as is /tools/local.m68k-rtems/bin/m68k-rtems-as
>> rtems> m68k-rtems-as --version
>> GNU assembler 2.13.2.1
>> I would appreciate some guidance here.
>> Thanks much.
>> Paul
>> Thomas Doerfler wrote:
>> >Paul,
>> >the files you are looking for are actually located under
>> >ftp://ftp.rtems.com/pub/rtems/releases/4.6.0pre5/tools/rtems-4.6-gcc3.2.3newlib1.11.0-1/source/newlib-1.11.0-rtems-20030605.diff
>> >and
>> >ftp://ftp.rtems.com/pub/rtems/releases/4.6.0pre5/tools/rtems-4.6-gcc3.2.3newlib1.11.0-1/source/gcc-3.2.3-rtems-20030826.diff
>> >wkr,
>> > Thomas.
>> >>The web page
>> >>http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0pre5/share/rtems/html/
>> >>has an entry that referrs to ' Getting Started with RTEMS for C/C++
>> >>Users
>> >><http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0pre5/share/rtems/html/started/index.html>'
>> >>that is a PDF file
>> >>'started-6.pdf'.
>> >>On page 14 of the PDF file it says:
>> >> RTEMS Speci c Tool Patches and Scripts
>> >> FTP Site: ftp.rtems.com
>> >> Directory: /pub/rtems/releases/4.6.0pre5/c_tools/source
>> >> File: newlib-1.11.0-rtems-20030605.diff
>> >> File: gcc-3.2.3-rtems-20030507a.diff
>> >>The directory /pub/rtems/releases/4.6.0pre5/c_tools does not exist.
>> >>Where can these patch diffs be found now?
>> >>thanks much.
>> >>paul
>> >IMD Ingenieurbuero fuer Microcomputertechnik
>> >Thomas Doerfler Herbststrasse 8
>> >D-82178 Puchheim Germany
>> >email: Thomas.Doerfler at imd-systems.de
>> >PGP public key available at: http://www.imd-
>> >systems.de/pgp_keys.htm
