m68k-rtems-gcc toolchain build problem on Solaris-7
Paul Cadaret
rtems at usd.com
Tue Dec 30 20:13:01 UTC 2003
Joel/Ralph,
It took my old Ultra-10 quite a while to finish the builds.
I found the problem. As I was double checking everything I did
yesterday, I noticed that the output from
the find command I used to search for all of the ocurrences of
'limits.h' had the following included:
../../src/newlib/newlib/libc/include/limits.h
../../src/newlib/newlib/libc/sys/linux/include/limits.h
../../src/newlib/newlib/libc/sys/rtems/include/limits.h
../../src/newlib/newlib/libc/sys/rtems/machine/limits.h
This morning I noticed this and I thought the 'newlib/newlib' part
looked a bit strange.
In reviewing the PDF file documentation again, it says:
4.1.4.2 Using configure and make
cd gcc-3.2.3
ln -s ../newlib-1.11.0/newlib .
Also, I just noticed that the unpacked newlib-1.11.0 archive contains a
'newlib' subdir. I just adjusted my
../../src/newlib sym-link to now point to this 'newlib' sub directory
within the unpacked newlib-1.11.0 archive,
re-configured, and re-ran make. The make then ran past the point of the
last error and ultimately completed
without error. A subsequent 'make install' also was run and completed
without error also.
This is not an error in the PDF file. It is my error.
However, perhaps a few extra words of warning about this in the docs
would be appropriate (for dummies like me).
Thanks you very much for responses. Sorry for the trouble.
Paul
Paul Cadaret wrote:
> Joel ,
> I listed a number of tools at the bottom of my post. I thought it
> would be important. Here's an excerpt.
> rtems> type gcc
> gcc is /tools/local/bin/gcc
> rtems> gcc --version
> 2.95.2
> rtems>
> Thanks.
> Paul
> Joel Sherrill wrote:
>> What native compiler are you using?
>> --joel
>> Paul Cadaret wrote:
>>> With help from Thomas (see below) I used the files he pointed out at
>>> ftp://ftp.rtems.com/pub/rtems/releases/4.6.0pre5/tools
>>> to run the build according to the PDF file at
>>> http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0pre5/share/rtems/pdf/started.pdf
>>> and I followed the PDF file instructions carefully for:
>>> 4.1.2 Unarchiving the Tools
>>> 4.1.3 Applying RTEMS Patches,
>>> Apply RTEMS Patch to GCC,
>>> Apply RTEMS Patch to binutils,
>>> Apply RTEMS Patch to newlib
>>> 4.1.4.2 Using configure and make,
>>> Configuring and Building BINUTILS,
>>> Configuring and Building GCC and NEWLIB
>>> Binutils built and installed without error.
>>> Building gcc-3.2.3 died as follows:
>>> 1113
>>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/xgcc
>>> -B/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/
>>> 1113 tools/gcc-3.2.3/build.m68k-rtems/gcc/ -nostdinc
>>> -B/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/m
>>> 1113 68k-rtems/newlib/ -isystem
>>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/m68k-rtems/newlib/targ-i
>>> 1113 nclude -isystem
>>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/src/newlib/libc/include
>>> -B/tools/local.m68k-rtems/m6
>>> 1113 8k-rtems/bin/ -B/tools/local.m68k-rtems/m68k-rtems/lib/
>>> -isystem /tools/local.m68k-rtems/m68k-rtems/include -O2
>>> -I../../src/
>>> 1113 gcc/../newlib/libc/sys/rtems/include -DIN_GCC
>>> -DCROSS_COMPILE -W -Wall -Wwrite-strings -Wstrict-prototypes
>>> -Wmissing-proto
>>> 1113 types -isystem ./include -g -DHAVE_GTHR_DEFAULT
>>> -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED -Dinhibit_libc -I. -I.
>>> -I../../src/g
>>> 1113 cc -I../../src/gcc/. -I../../src/gcc/config
>>> -I../../src/gcc/../include -DL_floatdisf -c
>>> ../../src/gcc/libgcc2.c
>>> -o libgcc/.
>>> 1113 /_floatdisf.o
>>> 1114
>>> 1114 tools/gcc-3.2.3/build.m68k-rtems/gcc/ -nostdinc
>>> 1114 68k-rtems/newlib/ -isystem
>>> 1114 nclude -isystem
>>> 1114 8k-rtems/bin/ -B/tools/local.m68k-rtems/m68k-rtems/lib/
>>> -I../../src/
>>> 1114 gcc/../newlib/libc/sys/rtems/include -DIN_GCC
>>> -Wmissing-proto
>>> 1114 types -isystem ./include -g -DHAVE_GTHR_DEFAULT
>>> -I../../src/g
>>> 1114 cc -I../../src/gcc/. -I../../src/gcc/config
>>> -I../../src/gcc/../include -DL_fixunsdfsi -c
>>> ../../src/gcc/libgcc2.c -o libgcc/
>>> 1114 ./_fixunsdfsi.o
>>> 1115 In file included from
>>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/include/syslimits.h:7,
>>> 1116 from
>>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/include/limits.h:11,
>>> 1117 from ../../src/gcc/libgcc2.c:1166:
>>> 1118
>>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/include/limits.h:132:75:
>>> no include path in whi
>>> 1118 ch to find limits.h
>>> 1119 make[2]: *** [libgcc/./_fixunsdfsi.o] Error 1
>>> 1120 make[2]: Leaving directory
>>> `/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc'
>>> 1121 make[1]: *** [stmp-multilib] Error 2
>>> 1122 make[1]: Leaving directory
>>> 1123 make: *** [all-gcc] Error 2
>>> ../../src/gcc/libgcc2.c looks like:
>>> 1155 #ifdef L_fixunsdfsi
>>> 1156 /* Reenable the normal types, in case limits.h needs
>>> them. */
>>> 1157 #undef char
>>> 1158 #undef short
>>> 1159 #undef int
>>> 1160 #undef long
>>> 1161 #undef unsigned
>>> 1162 #undef float
>>> 1163 #undef double
>>> 1164 #undef MIN
>>> 1165 #undef MAX
>>> 1166 #include <limits.h> <<<============== OK
>>> Note that ../src/gcc is where I unpacked the gcc-3.2.3 source tree and
>>> applied the patches.
>>> The above file includes ./gcc/include/limits.h:
>>> 9 #ifndef _LIBC_LIMITS_H_
>>> 10 /* Use "..." so that we find syslimits.h only in this same
>>> directory. */
>>> 11 #include "syslimits.h" <<<===============OK
>>> 12 #endif
>>> 13 #ifndef _LIMITS_H___
>>> 14 #define _LIMITS_H___
>>> The above file includes ./gcc/include/syslimits.h:
>>> 1 /* syslimits.h stands for the system's own limits.h file.
>>> 2 If we can use it ok unmodified, then we install this text.
>>> 3 If fixincludes fixes it, then the fixed version is installed
>>> 4 instead of this text. */
>>> 5
>>> 6 #define _GCC_NEXT_LIMITS_H /* tell gcc's limits.h
>>> to recurse */
>>> 7 #include_next <limits.h> <<<============= dies here
>>> searching
>>> for a secondary instance of limits.h
>>> 8 #undef _GCC_NEXT_LIMITS_H
>>> What is "the system's own limits.h file" ??? linux? solaris? newlib?
>>> rtems?
>>> The "#include_next" is a feature of the newer gcc's
>>> Disecting my build log line 1114 above looks like this:
>>> -B/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc/
>>> -nostdinc \
>>> -B/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/m68k-rtems/newlib/
>>> -isystem
>>> /sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/m68k-rtems/newlib/targ-include
>>> -isystem
>>> -B/tools/local.m68k-rtems/m68k-rtems/bin/ \
>>> -B/tools/local.m68k-rtems/m68k-rtems/lib/ \
>>> -isystem /tools/local.m68k-rtems/m68k-rtems/include \
>>> -O2 \
>>> -I../../src/gcc/../newlib/libc/sys/rtems/include \
>>> -DIN_GCC -DCROSS_COMPILE \
>>> -Wmissing-prototypes \
>>> -isystem ./include \
>>> -g \
>>> -DHAVE_GTHR_DEFAULT -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED
>>> -Dinhibit_libc \
>>> -I. \
>>> -I. \
>>> -I../../src/gcc \
>>> -I../../src/gcc/. \
>>> -I../../src/gcc/config \
>>> -I../../src/gcc/../include \
>>> -DL_fixunsdfsi \
>>> -c \
>>> ../../src/gcc/libgcc2.c \
>>> -o libgcc/./_fixunsdfsi.o
>>> From my build directory
>>> (/sd/c0t8d0/opt1/web/sites/ftp.rtems.com/tools/gcc-3.2.3/build.m68k-rtems/gcc)
>>> if I run the command below
>>> find .. ../../src /tools/local.m68k-rtems -follow -name limits.h
>>> -print
>>> shows the following:
>>> find: ../gcc/cp/stage1: No such file or directory
>>> find: ../gcc/cp/stage2: No such file or directory
>>> find: ../gcc/cp/stage3: No such file or directory
>>> find: ../gcc/cp/stage4: No such file or directory
>>> ../gcc/cp/include/limits.h
>>> find: ../gcc/fixinc/stage1: No such file or directory
>>> find: ../gcc/fixinc/stage2: No such file or directory
>>> find: ../gcc/fixinc/stage3: No such file or directory
>>> find: ../gcc/fixinc/stage4: No such file or directory
>>> ../gcc/fixinc/include/limits.h
>>> ../gcc/include/limits.h
>>> ../../src/gcc/fixinc/tests/base/sys/limits.h
>>> ../../src/libstdc++-v3/config/cpu/generic/bits/limits.h
>>> ../../src/libstdc++-v3/include/c_compatibility/limits.h
>>> ../../src/libstdc++-v3/include/c_shadow/limits.h
>>> The above list shows --ALL-- of the instances of files named
>>> "limits.h"
>>> available to this build; in fact, everything
>>> that might possibly pertain to the RTEMS tool sources I downloaded.
>>> The file "./include/limits.h" (aka ../gcc/include/limits.h) is the
>>> file
>>> that xgcc finds on line 1166 above.
>>> The file "syslimits.h" tries to use the "#include_next" mechanism to
>>> find a secondary "limits.h", however,
>>> the xgcc include path doesn't have any more files along the path. As
>>> best I can determine the xgcc include path
>>> should effectively be (from top to bottom):
>>> ../../src/gcc
>>> ./include
>>> Since 'configure' builds the makefiles here and I have no idea what it
>>> is trying to accomplish here, I really don't know
>>> what to fix. As best I can tell the Solaris toolchain is broken.
>>> Some further data:
>>> rtems> uname -a
>>> SunOS u2 5.7 Generic_106541-08 sun4u sparc
>>> SUNW,UltraSPARC-IIi-Engine
>>> rtems> perl --version
>>> This is perl, v5.6.0 built for sun4-solaris
>>> rtems> autoconf --version
>>> autoconf (GNU Autoconf) 2.59
>>> rtems> automake --version
>>> automake (GNU automake) 1.8
>>> rtems> gmake --version
>>> GNU Make 3.80
>>> 2.95.2
>>> rtems> type m68k-rtems-as
>>> m68k-rtems-as is /tools/local.m68k-rtems/bin/m68k-rtems-as
>>> rtems> m68k-rtems-as --version
>>> GNU assembler 2.13.2.1
>>> I would appreciate some guidance here.
>>> Thanks much.
>>> Paul
>>> Thomas Doerfler wrote:
>>> >Paul,
>>> >the files you are looking for are actually located under
>>> >ftp://ftp.rtems.com/pub/rtems/releases/4.6.0pre5/tools/rtems-4.6-gcc3.2.3newlib1.11.0-1/source/newlib-1.11.0-rtems-20030605.diff
>>> >and
>>> >ftp://ftp.rtems.com/pub/rtems/releases/4.6.0pre5/tools/rtems-4.6-gcc3.2.3newlib1.11.0-1/source/gcc-3.2.3-rtems-20030826.diff
>>> >wkr,
>>> > Thomas.
>>> >>The web page
>>> >>http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0pre5/share/rtems/html/
>>> >>has an entry that referrs to ' Getting Started with RTEMS for C/C++
>>> >>Users
>>> >><http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.0pre5/share/rtems/html/started/index.html>'
>>> >>that is a PDF file
>>> >>'started-6.pdf'.
>>> >>On page 14 of the PDF file it says:
>>> >> RTEMS Speci c Tool Patches and Scripts
>>> >> FTP Site: ftp.rtems.com
>>> >> Directory: /pub/rtems/releases/4.6.0pre5/c_tools/source
>>> >> File: newlib-1.11.0-rtems-20030605.diff
>>> >> File: gcc-3.2.3-rtems-20030507a.diff
>>> >>The directory /pub/rtems/releases/4.6.0pre5/c_tools does not exist.
>>> >>Where can these patch diffs be found now?
>>> >>thanks much.
>>> >>paul
>>> >IMD Ingenieurbuero fuer Microcomputertechnik
>>> >Thomas Doerfler Herbststrasse 8
>>> >D-82178 Puchheim Germany
>>> >email: Thomas.Doerfler at imd-systems.de
>>> >PGP public key available at: http://www.imd-
>>> >systems.de/pgp_keys.htm
