rtems-ss-20030128 problem
Ralf Corsepius corsepiu at faw.uni-ulm.de
Mon Feb 3 17:18:17 UTC 2003
Am Mon, 2003-02-03 um 17.48 schrieb Joel Sherrill:
> Francesco Poletti wrote:
> > Hy, in the last version of the snapshot I found this error: in the Makefile.am, of the shmdr directory, there was:
> > all-local: $(ARCH) $(PREINSTALL_FILES) $(PGM) $(TMPINSTALL_FILES)
> > When I build rtems arm-rtems-gcc don't found shm_driver.h I revert the order of all local in:
> >  all-local: $(ARCH) $(PREINSTALL_FILES) $(TMPINSTALL_FILES) $(PGM)
> > and now works. Is a mine error or a global error?
> I caught this over the weekend in a big build.  My fix is this:
> Index: Makefile.am
> RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/shmdr/Makefile.am,v
> retrieving revision 1.8
> diff -u -r1.8 Makefile.am
> --- Makefile.am 28 Jan 2003 14:57:10 -0000      1.8
> +++ Makefile.am 3 Feb 2003 16:39:49 -0000
> @@ -35,8 +35,8 @@
>  $(PROJECT_INCLUDE)/%.h: %.h
>         $(INSTALL_DATA) $< $@
> -TMPINSTALL_FILES += $(PROJECT_INCLUDE)
> -TMPINSTALL_FILES += $(include_HEADERS:%.h=$(PROJECT_INCLUDE)/%.h)
> +PREINSTALL_FILES  = $(PROJECT_INCLUDE)
> +PREINSTALL_FILES += $(include_HEADERS:%.h=$(PROJECT_INCLUDE)/%.h)
>  TMPINSTALL_FILES += $(PROJECT_RELEASE)/lib/shmdr$(LIB_VARIANT).rel
> Ralf, does this look right to you?
No, it doesn't. Your change changes pre-installation of these files from
"installation-on-the-fly" to "forced pre-installation".
>   The .h files need to be installed
> before the code is compiled and the .rel afterwards.
That's exactly the point needing to be investigated.
Therefore: Which part of RTEMS code makes you say this? I don't see it.
>   I think this is
> right.
It shouldn't do any harm.
> > Another problems if I put in the configure the options --enable-tests I have this error message:
> > checking for gmake... gmake
> > checking for RTEMS Version... ss-20030128
> > checking build system type... i686-pc-linux-gnu
> > checking host system type... arm-unknown-rtems
> > checking target system type... arm-unknown-rtems
> > checking rtems target cpu... arm
> > checking for a BSD-compatible install... /usr/bin/install -c
> > checking whether build environment is sane... yes
> > checking for gawk... gawk
> > checking whether gmake sets $(MAKE)... yes
> > checking for arm-rtems-strip... arm-rtems-strip
> > checking whether to enable maintainer-specific portions of Makefiles... yes
> > checking for RTEMS_BSP... arm_bare_bsp
> > checking if cpu arm is supported... yes
> > checking for style of include used by gmake... GNU
> > checking for arm-rtems-gcc... arm-rtems-gcc
> > checking for arm-rtems-gcc... (cached) arm-rtems-gcc
> > checking for C compiler default output... a.out
> > checking whether the C compiler works... yes
> > checking whether we are cross compiling... yes
> > checking for suffix of executables...
> > checking for suffix of object files... o
> > checking whether we are using the GNU C compiler... yes
> > checking whether arm-rtems-gcc accepts -g... yes
> > checking for arm-rtems-gcc option to accept ANSI C... none needed
> > checking dependency style of arm-rtems-gcc... gcc3
> > checking how to run the C preprocessor... arm-rtems-gcc -E
> > checking whether arm-rtems-gcc accepts -specs... yes
> > checking whether arm-rtems-gcc accepts --pipe... yes
> > checking for arm-rtems-ar... arm-rtems-ar
> > checking for arm-rtems-as... arm-rtems-as
> > checking for arm-rtems-ld... arm-rtems-ld
> > checking for arm-rtems-nm... arm-rtems-nm
> > checking for arm-rtems-ranlib... arm-rtems-ranlib
> > checking for arm-rtems-objcopy... arm-rtems-objcopy
> > checking for arm-rtems-size... arm-rtems-size
> > checking for arm-rtems-strip... (cached) arm-rtems-strip
> > checking for make/custom/arm_bare_bsp.cfg... yes
> > checking whether to build rtems++... no
> > configure: error: conditional "am__fastdepCXX" was never defined.
> > Usually this means the macro was only invoked conditionally.
> > configure: error: /bin/sh '../../../../../../rtems-ss-20030128/c/src/tests/libtests/configure' failed for libtests
> > configure: error: /bin/sh '../../../../../rtems-ss-20030128/c/src/tests/configure' failed for tests
> > gmake[2]: *** [arm_bare_bsp] Error 1
> > May anyone help me?
To be investigated. I recall this kind of bug being present in an older
snapshot, but I thought I had fixed it.
> I have see this but not been able to reproduce it enough to track it
> down.
> My 1st suspicion was that for some reason --enable-cxx must be set when
> you have multiprocessing enabled.  But I just tried that combination and
> can't reproduce that.  Any thoughts Ralf?
I need to look into the source-code. I could have missed something, it
could be a packaging bug, could be problems with autom4te.caches.
Ralf
