ISR Argument Proposal Request
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Feb 4 14:53:00 UTC 2003
Till,
I think that we are all as much in agreement over this as we
will ever be. Let's see if I can summarize and request that
you write up the API changes with a list of "key" area to
change.
Some issues that must be resolved:
+ should rtems_interrupt_catch be backward compatable and
this functionality have a new entry point? I lean to yes.
+ should this feature be optional and conditionally compiled?
The development plan needs to have volunteers for each of
the following:
+ generic change from table of handlers to table of
handlers/arguments
+ each port's irq handling
+ API changes to original interrupt API, ppc, x86, and ARM
+ documentation changes
+ any work break down I am missing?
NOTE: When you change a port, I would consider that to include
getting all the BSPs modified. Everything should still build.
I regularly build all BSPs so this is somethign I can provide
feedback on.
We can't start this until we are confident all
the ports will get updated.
joel at OARcorp.com On-Line Applications Research
